'97 Honda EX 2 dr - Timing Belt, Water Pump
sw ohio
People say it's the factory thread locker that makes that crank bolt removal a '10' in difficulty.
So I'd try some heat, propane, MAPP gas, etc. Even Red Loctite requires heat for ease of removal.
Mayb ,but I never saw evidence of thread locker on the bolt. It self tightens from rotation.
Cdn17Sport6MT
Vancouver, BC Canada
In a "mind-construct", so to speak, if the crankshaft pulley were a sloppy fit (by way of its keyway) onto the crankshaft, and it is the crankshaft itself that causes the pulley to rotate, and to the extent the bolt behaves as if it were fixed to the pulley... then in my mind's eye, the ccw turning crank self-tightens the crank bolt... as u said above.
