- Joined
- Jun 26, 2023
- Messages
- 56
2014 Acura RDX with 100k started making common bad hydraulic tensioner noise at start up. Bought the Aisin timing belt kit from Amazon (belt, roller pulleys, tensioner, water pump). Installed it. Only issue I had was rear cam pulley did spring forward 1/4 of a turn, which isn't uncommon. I rotated it back that 1/4 turn to its proper position. Turned engine by hand several times and all timing marks lined up. Drove it. No issues. After a day or so I got emissions warning message. Took it to parts store and their code reader showed ECU fault/timing off. Great! Pulled two upper timing belt/ cam pulley covers off. Marks still lined up. I did notice the tension on the belt on both "outer sides" of the pulleys (the side of the rear pulley closet to firewall and the side of the front pulley closet to radiator) were tight going down to the crank and tensioner, but the section of belt between the two cam pulleys had some looseness that I wouldn't expect, although I'm no authority on how tight the belt should be in that section. I pulled the harmonic balancer and lower timing cover off and timing marks on the crank and two upper pulleys were still in their proper positions. Thinking maybe I was one tooth off, I removed the tensioner and moved the belt one tooth over on the cam pulleys and it was obvious my initial belt positions were correct. So now what?!
Why was there some looseness between the pulleys? Is that normal? The belt deflects maybe 1/4" of an inch or slightly more. There was no deflection on the "tight" sections going down to the crank and tensioner unless you pushed it very hard.
Is the Aisin belt out of spec?
What would you do next?
As luck would have it, my only vice is just barely too small to fit the tensioner in to press it back in and insert the "grenade pin", which I would have to source a replacement pin because I tossed it in the bin like a total idiot thinking I'd never need it again.
I will add that I "think" I heard the "bad" tensioner noise on start up one time after installing the new tensioner. Wasn't the first start up. Maybe like tenth. Haven't heard it a second time
And I will also add that I did remove the plugs to make the engine rotate by hand easier and before I pulled the new tensioner to reposition the belt, after a couple manual turns of the engine, the looseness of the section of belt between the pulleys seemed to go away.
Should I just bite the bullet and buy a new belt and tensioner from the dealer? Some people claim the Aisin kits are hit or miss on quality these days.
Lastly, when the parts store guy was reading my trouble code, he tried to clear it while saying if I had unplugged the ECM, which I had to do during the belt replacement, the dealer needed to reset it because it would give me the trouble code I was seeing, implying there wasn't really an issue after all. I had never heard of this and didn't give it any serious consideration. Was I wrong? I'm at the point now where I wish I would've spent the $1200 and had the dealer fix it! Grrrrr!!!t
