Vad,
I have still in the family a 1986 VW jetta that just turned 250k miles.
So that works out to 13,200 miles a year.
Would we agree that this is a "normal" amount for a outfit?
I'd say most of it's life it saw commutes in the 10 mile one way city and trips here and there.
Never had a single problem with it. Passes all smog and runs just as good as it did when it was new.
Oil used. Havoline and Valvoline mostly and fram filters at 4-5k OCI. Also in Utah where it gets below zero to over 100 easy.
We would agree that todays oils are better than 19 year old oil spec'd for 1986?
How clean is the engine? We had the valve cover off a few years ago to fix a leak and it was spotless. You can look in the fill cap and it's still clean.
You do NOT need to run syn to have a "clean" engine.
You do NOT have to run Syn to have a motor last.
You will not ever run syn long enough to make it "cheaper" to run syn over dino.. (Remember that I only buy oil on sale and stock it up
so I'm using under $1 a quart for name brand oil as my base vs $4 a quart Syn.)
I'll always change out oil every 4-5k even when out of warrenty. In my sick mind, I'd rather change it at that OCI and save the $$.
Also, unlike some folks here at BITOG.. I like working on my outfits and only buy cars that are easy to work on..
(yes, When I buy cars.. I look for oil filters, drain plugs and such.. (and tick off my wife in the process..
With my 1999 Taurus, We tore the engine down twice (62k and 110k) and both times it was spotless (nothing.. Not even a tint) using Pennzoil dino that I bought for .69 cents a quart and ST filters. And it was a buyback Hertz rent-a-car with 21k when I bought it so you know it did not get 3k OCIs...
My 2000k Chev which gets now maybe 1000 miles in 4 months is spotless inside. 1 mile one way trips seems to be the majority of the use since gas wnet up and I'm driving the toyota. (Sad use of this fine truck... I am prob going to sell it...
And I could go on. If you like and want to run syn, EXCELLENT!
But your correct, I think if we had this GP running on Castrol, Pennzoil, Mobil drive clean, QS or such, the results would be prob the same.
Good dino oil is good! And unless you have a Turbo or some real racer, Syn is really not needed for long clean life of a engine.
Take care, bill
