Edit time ran out..
Saturnfans.com is great, I have been a memeber for many years, and my its a huge help if you own a saturn S.
from
http://www.saturnfans.com/forums/showthread.php?t=149588
2001 SL2 with 89,565
This was an inexpensive fix and fairly easy if you remove the wheel:
Tools:
-Jack
-Jackstand
-Tire iron
-13/16 Socket
-10mm deep
-10mm shallow
-3" extension
-14mm open-end
-Hammer
-Flathead
-Blue RTV
Apply E-brake, block the rear wheels, Raise the front passenger side, and set the framerail on a jackstand like so:
Remove the wheel and 2 inner splash sheilds. (3 plastic rivets)
(^^This pic was shot after completion)
Before removing the belt, crack the water pump pulley bolts loose while the belt tension keeps the pulley from moving. Use the 13/16 to rotate the crankshaft to get to all 3 bolts(10mm). If there's not enough tension on the belt you will need to find a way to hold the pulley such a strap-wrench.
After breaking the bolts loose, use 14mm box wrench to release the tensioner. From the bottom, pull the wrech toward the from of the car. Tensioner shown here:
With the belt removed, take the 3 10mm bolts out to remove the pulley and set it on the frame rail in front of the engine:
^^That's a 89k mile oem stamped steel pump. Nasty.
Time to drain the coolant if you havent already. Place a bucket under the draincock and unscrew. You wont get quite enough out but it helps. Not sure if this model has a block drain.. I forgot to even look for it.
Use a combination of deep 10mm, shallow 10mm, and the 3" extension to remove the water pump bolts. I accessed 2 from the top and the rest from the bottom. Punch holes in a box in the same pattern as the bolts so they go back in their original holes:
Pry the pump off the block with a screwdriver and be ready for antifreeze to dump out. I used some 320 grid wet sandpaper to clean the mating surface:
Apply a thin layer of blue RTV to the pump mating surface, set the paper gasket in place, then apply another thin layer to the gasket. Put the pump in place and thread the bolts snugly into their original positions, then tighten them in a crossing pattern. They are spec'd for 22lb/ft but good luck getting a standard torque wrench in there. Remember, the block threads are aluminum and will strip before the bolts do. I'd rather do this job 10 times than have to lift the motor and tap the block...
Next, replace the water pump pulley. This was the hardest part because I didnt have a strap-wrench to hold the pulley while tightening the bolts. I used an old serpentine belt wrapped around the pulley and tied to one of the engine lift points - it was barely enough. I'll pick up a strap wrench for next time..
Let the RTV set for an hour or so, replace the belt, then close the radiator draincock and refill with a 50/50 mix of your favorite antifreeze. I prefer to mix it with distilled water in a clean bucket to get the mix perfect. Start the engine and run the heater on high, keeping an eye on the gauge. It will take a few heating / cooling cycles to get all the air out of the system.
Replace the splash shields and wheel AFTER running the engine to operating temp and checking for leaks.
Total cost was about $53 for pump, gasket, and a new belt.
Just curious: What would a shop charge for this?
