The ex-girlfriend has a '93, with 2.0L auto and about 130k miles that I've been maintaining for the last seven years. I enjoy driving it. Steering feel, suspension, and handling are very good. It's just starting to get some body rust. It has been reliable, and I've only changed a few things that would be typical for any car at that age, like the radiator, CV boots, most of the exhaust, and an oil pressure sending unit. The rear stabilizer bar links broke last year but I just removed it.
The rear brakes were completely seized when I met her. That may be a common problem. The transmission also shifted very harshly. It shifted so harshly it would squeal the tires going into second. The fluid had been changed at the Mazda dealer at one point, and I think they used the wrong fluid. A fluid/filter change and a few more drain-and-refills (yay for drain plugs) using Supertech DexIII fixed that. Not a great auto, but it works well enough. The rear deck was squeaky so I removed it and stuffed some foam under there.
Her best tank was 5.9L/100km (40 usmpg) on a 400 mile highway trip. The norm is about 8 (30). I've never seen more than a half-quart of oil consumption between changes. I had a bit of trouble finding a filter wrench to work with it. The filter is very small and hard to access by hand, and always empty when I remove it, no matter what brand of filter is used.
She's at 70k miles on the timing belt. I planned on changing it at 90k.
I think I did a search on her transmission one time and determined that it wasn't one of the bad ones; they came either later, earlier, or only with the V6. I can't remember any details though. Edit: I looked into the Ford CD4E mentioned above, and it was used beginning in '94. The '93 has the GF4A-EL.
