Hi Folks - HELP!,
I need some guidance and probably from Bob the Oil Guy himself. The automatic transmission in my ND MX-5 has travelled 46,000 Kms. I had my licensed local mechanic do a transmission oil change/flush with Liqui Moly Top Tec ATF 1200 (Approvals - (Dexron IIIH and JASO 1-A) and recommended for transmissions classified as JWS3309 as per my MX5 Owners manual. Mazda's recommended automatic transmission fluid according to their "Lubricant Guide" is Castrol Transmax Multi Vehicle (Specifications - Dextron IIIH and JASO M315 Type 1A Specification). Note - Approvals Vs Specifications
Since flushing the existing original Mazda fluid and replacing with Liqui Moly Top Tec ATF 1200, the auto transmission now has a shudder at low rpms in higher gears - 4th-5th between 1400-1800 RPM when going up slight inclines - it is gradually getting worse.
Mazda are saying they will not replace the Auto Trans under warranty as the auto trans oil I have used is not the Mazda recommended oil and that the shudder has occurred after changing the oil to Liqui Moly. I had Castrol Transmax Multi put back in the Auto Trans after travelling 400 Kms on the Liqui Moly - but the shudder remains.
Does anyone have an opinion on where I stand. I think changing the trans oil has bought to light an underlying mechanical issue in the Auto Trans - as Mazda inspected the pan - reported metals shaving and said Auto Trans need to be replaced. They then said, because I have not used the Mazda recommended auto trans oil - it will not be covered by warranty. I will need to fight this legally, a new Transmission installed is $11,000.00 Australian Dollars/ $7,700 US Dollars - how could a trans oil with Approvals to the same specs as the Mazda recommended trans oil cause the transmission to fail/shudder resulting in replacement? I have spoken to 2 Auto Trans specialists who say the trans oil is highly unlikely to have caused the issue - but they will not put this in writing/on letterhead.
Mazda are requesting at my expense to pull the auto trans, open it up and have a specialist advise on the root cause of the failure at my cost. If they agree, then they may do something. If they dont - I have an open trans, a $1200 bill and more money to fix issues + another $1200 to fit it again.
Any advice or how I can use an expert to refute their claims the Liqui Moly Trans oil is to blame for the shudder and metal shavings in the trans oil pan would be appreciated.
Note - Mazda Automatic Transmission Model: SJ1419090 - 6 Speed Sports Automatic
Thanks Scott.
Thanks Scott.
