90915-YZZN1 Failure/C&P
2017 Toyota Prius
146k current mileage
Mobil 1 Advanced Fuel Economy or EP since purchased at 99k
Unknown miles on this OCI, maybe 4k.
I just change it based on the MM.
Out: 90915-yzzn1, Mobil 1 Extended Performance 0w20
In: Mobil 1-203a (import) Mobil 1 ESP 0w20
Normally don't track or C&P on this vehicle but I saw a post talking about these Denso filters separating at ths glued base and had to cut it and see.
I had replaced the denso with another (newer) one, but upon cutting this one open, I swapped it for the Mobil 1 filter. The newer Denso looked fine internally.
Thanks for the C&P! It's interesting to see this failure, normally these Denso made filters are top notch. PGI only I suppose, even for Toyota.
Here's my last C&P of one.
That one looked great. The denso is all I've put on this car over several changes, but this is the first change since I've had a cutter (or the reason to cut it)
Not catastrophic but a reason to change your oil/filter frequently. It’s a failure to expect based on the design and I wondered why it didn’t happen regularly. It’s basically a chronic bypass. This probably happens frequently but isn’t documented as most folks don’t open their used spin on filters.
The only way I can think of is the machinery may angle the center tube slightly on assembly and cracks the glue. Its at the adbv end where it is usually cut, maybe sideways pressure or tilting the can with strong hands as it breaks could do this.
Recently purchased 6 N1 filters from my local Toyota dealer at just under $5 each. 5k/6 month OCI in my Toyotas. not going to loose any sleep over this
Can you make the glue ring fail by spreading pleats apart with your fingers near the pleat ends? Is it brittle and weak?
