Originally Posted By: ram_man
Really? You guys are just plain ridiculous . Sounds like this forum is being over run by trolls and [censored] disturbers.
Best thing to do if you think someone is trying to 'troll' you is to ignore them and reply to the people trying to help you. Trolls only live by what their fed, don't feed them and they die. That being said, the person who seemed to be trolling you may have actually wanted to help and there was miscommunication. If so then they will likely chime in when they see a point where they can help.
Thank you for the great advice, I just didn't know if maybe there was a common culprit for this issue on these trucks.
Tomorrow will be the day we go through it.
To be a little more helpful. He told me today he was adjusting the distributor by ear and he shut it off to adjust and after the 3rd time no more power......
The reason i was so vague is I don't have a whole lot of info to go on.
I was told it was dead the lights didn't work and neither did anything else. I relayed the information on here and I guess a couple people go loopy when they aren't written a novel. Well I originally told you guys what I knew I could have done it in a few words or several hundred but does it honestly make a difference? Sorry to the few who misunderstood or took my words out of context . I wasn't trying to be unclear.
So, to confirm this, he did not have power the other day, but then today he had power while adjusting the distributor but then after the third time he had no power at all? I.e. intermittent power?
Also to confirm, 'no power at all' meaning no dome lights, no headlights, no annoying key beep, NOTHING that would indicate any power anywhere?
I had something akin to that on my 88 Burb. It usually started and ran fine, but occasionally it wouldn't have any power at all even if it had just been running. Jiggle the wires on the top of the engine would sometimes get it to start. Seeing as your friend was working on the distributor perhaps there is a loose wire responsible? Try jiggling the wires again.
My problem was ultimately fixed with an ignition switch which
may be your problem, but again, can't know for sure until things are fully diagnosed(that is one thing I learned, don't go changing out parts until you're at least 95% sure that is the problem).
Also, more info is always better, but since you had hardly anything that's understandable. If you two worked on it today and are still having issues please post some of the things you tried and/or looked at. Something may be the key for someone here, never know!
