- Joined
- Jul 16, 2024
- Messages
- 83
Hi folks. I have a '92 Chevy C1500, 5.7 with 162k miles (owned since new). Been running Shell T5 15w-40 for a few years. A few months back, it developed an engine knock. Oil pressure in the past year has dropped somewhat, around 30ish at 50/60mph, and 10+lbs or so at hot idle. Not a ping or rattle type sound, a sort of deep knock. One shop said it might be the flex plate, but it checked out fine. They said it could be lower engine, but they don't do lower engine repairs.
Here's the things I can rule out causing the knock. All the front engine accessories are new (pow/steering original, but it's quiet). I replaced both exhaust manifolds and Y-pipe, no leaks there. In fact, virtually every sensor/component on the engine has been replaced over the last couple of years.
Here are the symptoms: the engine is quiet at startup, but within a few miles (reaching operating temp), the knock starts up. Changing serpentine belt can make the knock go away (to a degree). Looser belt, no knock, tighter belt knock shows up. Another mechanic said it was main bearings.
Pulled a few plug wires, and the knock all but disappeared at cylinder #2.
So, could this be main bearings, or rod bearings or what? Haven't pulled the pan, but can if I need to. Thanks.
