My sister has a 2006 Toyota Matrix 1ZZ-FE she bought a few months back based on my recommendation (never again).
The car has been been a nightmare for us since she lives 3 hours away in a big city with ridiculous traffic and dangerous driving. Her 2005 Camry was totaled in an accident there and this is what we found to replace it. I'm really trying to help her figure out the problem and fix it but with very little access to the car.
It has and always had a constant p0352 code for ignition coil circuit B. It stays on that cylinder even if you swap the coils (seller told me this - he suspected a bad wire to the coil). Intermittent dead miss that doesn't actually set any other codes. I'm assuming it's cylinder 2 but in my presence it's never misfired long enough to see the misfires.
It went to the shop for a safety and fix the code, they replaced the coil on number 2. They said it had no codes when it left and they drove it for half an hour and it didn't act up.
I have driven it over an hour round trip and it didn't act up (last time she came home).
It will randomly lose power, shift erratically, (either not upshift or not downshift from what she tells me). One day if refused to crank or start...she tried playing with the shifter (neutral safety switch) etc nothing would get it to respond. Eventually it got towed because construction workers were going to have it towed if she couldn't get it out of there.
When the shop it was towed to finally got to it it fired right up no issues present. Hasn't done that since.
These vehicles had a recall for the ECM but it apparently didn't apply to Canadian vehicles, only American ones. The shop that safeties it says they suspect an ECM issue as they've seen that a number of times on these vehicles.
A bad ground is also a possibility. I paid for Identifix - direct hit DIY just this morning so I can access wiring diagrams and stuff (have experience with this site from when I was a service advisor).
I know it's a long shot and we basically need to spend the time to test things properly but hoping someone has some personal experience with this problem on one of these or a Corolla. I'm really hating this car right now.
