I know you guys aren't going to know im just curious as to what all you would check.
"Died" is so subjective that it's useless. You're right, I am not going to know...because there is no information on which to proceed...
Did you even read my post? I said there is no lights no radio no cranking it is basically an over grown rusty paper weight.
Of course I read your posts...completely...and they were next to pointless...
The first post had little information, and vernacular (dead) that was known only to you.
The second was condescending...presuming that, with little information, this forum would get it wrong....yep, you're right, if you provide insufficient information, it's likely that no one can figure it out...
So, when want help from a group, you start by providing insufficient information, followed up with condescension, bordering on insult.
I have to know, does this approach often work for you?
You ask a group for help by making it hard for them? Then insult them?
Look, the only fact that you have conveyed is that no electricity is getting to key systems.
My 12 year old, who has a clear grasp of logic, would say that there are only two possibilities:
1. there is no electricity available(the battery is dead, and your friend's assertion on the battery being new/good is a red herring).
2. there is a break in the path (bad ground, bad cables, etc...all of which have been discussed.)
But I didn't chose to diagnose, since you said that, "I know you guys aren't going to know"...when, actually, I might know...but you made it really hard to care if you solved this or not...so, if you would like to know how I would troubleshoot, I would:
1. Jump it to ensure that there is electricity from a known good source.
2. Check connections, to ensure that it can flow.
But if that's too hard...and you would rather choose to believe that the fault is in my reading comprehension...well...then, good luck with this thing...
Sir I am pretty sure you are taking things out of context... I know none of you is just going to know what is wrong. I just want some ideas and advice. Also I am pretty sure everyone understood what I meant, except for you. So instead of getting all high on keyboard why don't you take a chill pill and stop being rude.
Thanks again for the understanding
