The Mid-Exit door already exists on the 737-900 (NG) as an “option”. I’ve only seen it on foreign carriers, likely once they get past 200 seats in a single class configuration. US carriers should all technically have the opening, but there’s a non-openable plug installed where the door would be, usually.
As for space, I wouldn’t be concerned. In the US, you should have more legroom with the MAX-10. I believe United has 179 seats in their 737-900s and Delta has 180. Both United and Delta are advertising 182 seats in their MAX-10s. So only 2-3 extra seats in a 66” longer fuselage.
It’s rumored United will have a Premium Configuration with even fewer seats, including 22 lay-flat seats.
As for bathroom, there should be 4 on US Domestic MAX-10s. Most Domestic 737-900s already have 4. This shouldn’t be any less.
Delta does 3 in back and 1 in first class. United does 1 in first class, 1 behind first class and 2 in back.
Here’s the dummy Mid Exit door on UA and DL 737-900s. The interior is covered over, so you’d never know it was there from the inside (except for the window spacing)
