70 460 - break-in oil recommendations please
Originally Posted By: Clevy
Originally Posted By: turtlevette
What's wrong with the Delo you have been using. That should have a high content of anti wear additives.
Upon initial startup, take it up to 3000 rpm and hold it there for 30 minutes, keeping an eye on temp and oil pressure. That's the best way to break-in a new cam. The rest of the parts in the engine do not respond as much to break-in.
So your suggesting running the engine at 3000rpm with no load. No wonder your TA has no compression in 2 and 4.
OP
The wheel isn't being reinvented here. I've rebuilt 3 of my own engines as well as 4 with friends,not including the cam swap in my 99 chev z71.
I also installed the big bore kit on my Harley,with a drunk experienced friend there overseeing the whole operation.
In every case I took the vehicle/bike onto the highway and ran 2nd and 3rd gear pulls. Going 3/4 throttle thru both gears then down shifting to load the rings do I was loading both ways,with acceleration and deceleration.
I ran from my place in the city to my girls place(30 miles)then changed the oil and filter. Drove normally after that.
Nothing is consuming any oil yet,and in the Harley I'm running thinner than spec oil,the cars and truck are running spec oil with no consumption either.
Sounds like you've got a great engine there. What is it in,or what are you putting it in.
1970 Lincoln MK III is where that baby is going...
OP
Sounds like you've got a great engine there. What is it in,or what are you putting it in. [/quote]
1970 Lincoln MK III is where that baby is going...[/quote]
Well you will certainly need all those cubic inches to get that land yacht moving.
Growing up my parents had a 76 Lincoln. That car would tow our 22' trailer across multiple provinces with those fender mount mirrors hanging off the side.
I remember my sister and I both being able to lay down in the back seat to sleep,and the front center armrest is where I'd sit.
Good times,cool car OP.
