I just got these codes from ScanGauge to program an X-Gauge into the ScanGauge so it reads the temperature in the transmission of the 62TE 6 Speed Transmissions found in the 2012 - 2019 Dodge Grand Caravans.
I thought I would post in this section for future reference for those searching the Internet for this information, as you need to know the temperature of the fluid in the pan for correct refilling procedure using a measuring dipstick like the one Dorman makes. Not everyone has access to a proper scan-tool to read this information and most cheap ones will not do it, but they might have a ScanGauge or have a friend that has one. Or might just want to watch the temperature as they are towing.
X-Gauge Programming codes:
TXD: 07E022B010
RXF: 046205B00610
RXD: 3010
MTH: 000100400000
Here is a link to the dipstick from Dorman that is needed: https://www.dormanproducts.com/p-52514-917-327.aspx
Dorman Part Number: 917-327 (Sold on Amazon, Rock-Auto and other places)
(This transmission doesn't have a dipstick normally)
This also works on the VW Routan vans that are essentially Dodge Grand Caravans.
Procedure as per Chrysler:
1. Verify that the vehicle is parked on a level surface.
2. Remove the dipstick tube cap.
3. Actuate the service brake. Start engine and let it run at idle speed in selector lever position "P".
4. Shift through the transmission modes several times with the vehicle stationary and the engine idling.
5. Warm up the transmission, wait at least 2 minutes and check the oil level with the engine running. Push the Oil Dipstick into transmission fill tube until the dipstick tip contacts the oil pan and pull out again, read off oil level, repeat if necessary.
NOTE: When inserting dipstick special dipstick, excess force may cause
the dipstick to slip past the stop on the bracket in the transmission oil
pan. The dipstick should be inserted into the fill tube approximately 16.7".
The dipstick will protrude from the fill tube when installed.
6. Check transmission oil temperature using the appropriate scan tool.
7. The transmission Oil Dipstick has indicator marks every 10 mm. Determine the height of the oil level on the dipstick and using the height, the transmission temperature, and the following graph, determine if the transmission oil level is correct.
8. Add or remove oil as necessary and recheck the oil level.
9. Once the oil level is correct, install the dipstick tube cap.
Here is the temperature / measurement chart:
TXD: 07E022B010
RXF: 046205B00610
RXD: 3010
MTH: 000100400000
