Automatic transmission fluid level
Houston Texas
Skip down to --------------- below if you want to get right to it!
I have been doing some suck out from the dipstick tube and replace with fresh Dexron VI in my 2007 Chevy Tahoe with ~~71,500 miles.
This is the first new fluid since original fill. I checked the level on 178 degree transmissionmission and it was in the correct zone closer to the low side mark but just under half way.
I took out 2.4 quarts out when transmissionmission was 180 degrees and put back in 2.4 quarts of room temperature fluid.
Then when I checked at 180 degrees it was between the marks closer to the hot side - say 3/4 from low mark.
I then sucked out 2.2 quarts and put 2.1 quarts back in.
I am now about in the middle between high and low with transmissionmission at 180 degrees.
I have one more to go - and I plan on doing it room temp out and in.
Owners manual says -
Check it with temperature between 160 and 200 degrees - if it is between the low and high marks on the dipstick it is good.
It seems like I may be over thinking this stuff (I do that)
But if you check it at 160 degrees and it is almost to the high mark - it would be way over that if the temp was 200 degrees. Is it built to handle that?
Or you are close to the lower mark on the dip stick with the transmission at 200 degrees it would be way below the mark at 160 degrees.
If I really want the correct amount shouldn't it be about in the middle of the range when the transmission temp is 180 degrees?
I do not want it over full.
Check at 160 to 200 degrees and top up as needed to not exceed the Full mark. Check it at operating temp/a few miles at minimum drive. Don't worry that the new fluid is room temp. You're not going to add much to top it up and it doesn't expand enough for a cup to make a difference.
It isn't that exact that one needs to sweat over it.
To make it simple keep the level between the marks whatever the temp is.
The 160 may be the temp that the cooler thermostat opens at. That will provide flow throughout the entire system and 160 would be adequate to account for the slight fluid expansion when hot. Any check should be done above that (which you are already doing)
Sounds like youve got it handled.
