Where can I get one?
https://www.msn.com/en-us/autos/ent...out-forced-induction/ar-AAS1ZCF?ocid=msedgntp
c502, is it true that the Cleavland 2V heads flow better than the 4V heads stock from the factory?Interesting, but not surprising since the custom head is Boss 302/Cleveland big port based, that they used the same port tricks that I used on many 351-4V Cleveland motors I built in the 80's and 90's. It's a pretty common mod to increase flow in a very large port.
At low RPM's definitely. The Cleveland hot tip was the Australian head. 2V ports with the 4V closed chamber. I used to import them by the pallet!c502, is it true that the Cleavland 2V heads flow better than the 4V heads stock from the factory?![]()
Carefullyhow do you weld the extra 2 chambers onto the 4 and get it to seal (and flow water) correctly?
1971 BOSS 351 owner
Steve "R"
1971 BOSS 351 owner
Steve "R"
