Do I have to use 5w30 in my CTS-V? or Can I use 5w20 or 10w30?
jupiterdagger said:I would stay away from most 0W-20s (especially your 'faves' the TOY/Idemitsu variety), NO MATTER WHAT his oil pressure/temp gauges say. The stock boost on that engine is fairly high, as is the stock WOT enrichment programming.
The TOY stuff might be OK if he lived inside the Artic Circle during winter time, but otherwise, I would avoid it like the plague in THAT powerplant.![]()
An engine no matter how powerful doesn't know what grade of oil is in the sump just what the operational viscosity is at any given moment. That's why you can run a 0W-5 qualifying oil in a NASCAR engine flat out for a few laps as long as the oil temp's don't exceed say 180F.
An oil pressure gauge is effectively an onboard viscometer.
GM V8s can run safely with OP in the low 40 psi range without issue at high rev's consiquently 50 psi is a very conservative lower limit which translates into a fairly viscous oil.
Since street driving so under stresses a high performance engine it is very easy to run a light oil as the oil temp's usually stay very low.
Since most owners of high performance cars are (I hate to say) poseurs that drive no faster than you're typical Prius owner, they don't need to run a heavy oil and the lubrication demands of the engine would be better met in running a lighter than spec' oil.
OP is how you determine what the correct oil viscosity is for any application.
