Oh, when I get around to it I'll install a relatively expensive oil temp gauge. I'll put it on my list of stuff for my son to do while I supervise. Remember I'm in a holding pattern with a herniated disc and while gauge installation may not be considered a labor intensive task, you might be surprised on what playing just a little twister can produce in gut wrenching "discomfort" ..with residuals. The gift that keeps on giving.
Trans and Oil temp gauges are next. Oil temp pretty much hangs right around coolant temp. I have an exchanger. You can more or less see the coolant stuck at the thermostat level until the oil gets close enough to allow the rad to bleed off more heat. Then it will start varying a bit.
If I really want to complicate things I have a 95C thermostatic sandwich adapter. I don't know yet if I'm going to plumb it to an auxiliary rad cooler fastened behind the rad, or plumb it to a Dual Guard with two EaBP110 for an 8 quart sump.
One of my original (intended) experiments with Bruce's first formulation was to test the two stage sump. Member Curious Kid proposed a two tier sump that would operate on 2 quarts during start up so that it would warm quicker, then transition to the full 4-5 quart sump as oil temps breached sensible thresholds. I couldn't do that, but I could manage to have an 8-9 quart sump appear initially as a 5 quart sump using thermostats and heat exchangers.
I had a modified Crown Vic Laminova heat exchanger in line on the outlet to the rad, and two Eaton tow motor trans coolers plumbed to a bypass circuit. While cold, the Eatons were dead and the oil flowed to the Laminova on the upper rad hose. That warmed the oil only from waste heat. Once the oil reached 180F+/- the thermostat diverted the oil flow to the Eatons for cooling. An additional thermostat plumbed a older Crown Vic drag/police pack radiator and a Hayden 36x18 rad cooler.
The idea was to use the light weight 0w-10 in a 5 quart virtual sump, but force cool it to at least a 20 weight when it was at the full system capacity.
I later found that it was unnecessary to temperature compensate for the lighter fluid.
Some areas under the hood had an appearance not unlike a scene where Aliens had set up shop. You don't know how hard it is to change hose sizes on a budget.
