Just a quick note re. motors designed for 5-20
, Honda spec in Europe is 5-30 in US 5-20. So what oil is Honda set up for?? Both??
Originally Posted By: StevieC
My engine manual and oil cap call for 5w20. In my technical manual it calls for various different weights based on ambient operating temperature.
Being a skeptic of the 5w20 weight and CAFE standards I ran 5w30, 0w30 and 10w30 in my engine it's whole life and got really good UOA's that were all the same pretty much from brand to brand as I experimented to find the best.
With over 192K miles (320K KM's) on the clock I decided to give 5w20 a try again and do a UOA so I could compare it to the same brand and other brands UOA's I have.
This was within the last month and we had been experiencing a heat wave of 90-100F days.
I ran 3 consecutive runs before doing a UOA to ensure the engine was "used to it" and when the numbers came back I was amazed. (See UOA section - RLI 5w20)
I had almost all 0's on the report for wear metals with exception of normal Iron levels. The additve package was also barely touched in my run.
This made me a believer in 5w20 oils and I think I will run this weight from now on even though my engine has many miles and could be slightly worn and the fact that it currently has a fuel dilution problem going on that I'm trying to pinpoint the cause.
Another supporting example for 5w20 is my dad's Windstar. It has over 300K KM's (240K miles) and has run on MotorCraft 5w20 (now anything 5w20) its whole life and it runs great and passes emission tests with flying colours. It doesn't burn or leak any oil too!
The previous owner towed a boat with it and was laxed when it came to maintenance so oil changes were pushed beyond the norm. and things like tune-ups and radiator flushes were only done when needed. We had to replace the rad because it was plugged with sludge and running hot. (But just so you know the oil didn't have an easy life)
I will be honest that it has Piston knocking on cold start up for the first few minutes on one of the cylinders but this I think is largely as a result that the engine was abused before we got it and not the oil used because all the other cylinders, bearings and pistons are fine.
Your call but that is proof enough to me that 5w20 is fine to use in engines that are designed for it.
