I'm looking for a full synthetic oil that meets or exceeds BMW LL-01 that can be used in my fully deleted OM642 turbodiesel Mercedes and my wife's bone stock Mini with the 1.6 NA engine. Any recommendations?
What BMW?I'm looking for a full synthetic oil that meets or exceeds BMW LL-01 that can be used in my fully deleted OM642 turbodiesel Mercedes and my wife's bone stock Mini with the 1.6 NA engine. Any recommendations?
No LL designation which some might not like, even though it would pass.Technically Mobil1 ESP 0W30 can do all.
There is ESP 5W-30 that is LL-04.No LL designation which some might not like, even though it would pass.
Yes I agree that the lack of LL-04 for Mobil 1 ESP 0W-30 is no big deal, and it would do great. People will have varying degrees of comfort with this.There is ESP 5W-30 that is LL-04.
ESP 0w-30 not being LL has been discussed and doesn't matter unless you want to stick .to LL for warranty insurance and/or feel secure.
Most likely ESP 0W-30 doesn't pass the BMW oxidation level due to the high percentage of esters is all. Because I have a MB OM642 specced for MB 229.51/52 I simplified supply and I've switched Daughters 2008 N52 to it for 4 years and it hasn't blown up. My 2010 N52 would be on it, but I got a hair to try HPL Supercar.
Yeah, 0W30 besides esters also has a higher ZDDP level.Yes I agree that the lack of LL-04 for Mobil 1 ESP 0W-30 is no big deal, and it would do great. People will have varying degrees of comfort with this.
Not easily available in USA.Valvoline SynPower MST C3 5W40 is the oil you desire
Most things that are worthwhile aren't easy.Not easily available in USA.
Do you ever have any technical reasons for making these constant Valvoline recommendations?Valvoline SynPower MST C3 5W40 is the oil you desire
Please explain why I should go through that effort, rather than just walking into Walmart and buying off-the-shelf.Most things that are worthwhile aren't easy.
I agree with you 100% .Please explain why I should go through that effort, rather than just walking into Walmart and buying off-the-shelf.
It's a 2014 Mini Countryman with the 1.6 liter N/A engine that calls for LL-01. I've been using Castrol Euro 5w-40 in that one, and Delvac 1 ESP 5w-40 in my deleted diesel Mercedes. Both cars are out of warranty, but we are planning to keep them long term so I'm more concerned with protection than anything, which is why I'm running 5w-40 in both. We live in Florida so winter starting is not an issue.What BMW?
I found this oil on Amazon so I may give it a shot. I like that it says "for gasoline and diesel" on the bottle. I also like what Valvoline has been doing lately with the Valvoline Restore and Protect line, seems interesting for keeping carbon buildup at bay. Do you know if this Euro oil has similar chemistry to Valvoline Restore and Protect, and how would it compare to either Delvac 1 or Castrol Euro when it comes to unsticking stuck rings and/or keeping rings from getting stuck? Both cars use about a quart of oil between changes which I know is probably within the acceptable range, but my OCD would like to get that amount to zero and I suspect rings may be the culprit on both engines.Valvoline SynPower MST C3 5W40 is the oil you desire
There is zero reason to pay more on Amazon for that oil over something at Walmart, plus the fact that it does not have Longlife-01 approval as you were asking about. The poster goes from thread to thread shilling Valvoline products with no technical reasoning to support his constant promotions.I found this oil on Amazon so I may give it a shot. I like that it says "for gasoline and diesel" on the bottle. I also like what Valvoline has been doing lately with the Valvoline Restore and Protect line, seems interesting for keeping carbon buildup at bay. Do you know if this Euro oil has similar chemistry to Valvoline Restore and Protect, and how would it compare to either Delvac 1 or Castrol Euro when it comes to unsticking stuck rings and/or keeping rings from getting stuck? Both cars use about a quart of oil between changes which I know is probably within the acceptable range, but my OCD would like to get that amount to zero and I suspect rings may be the culprit on both engines.
Castrol 5W40 is average oil at best. What you looking for is HTHS, not grade. The reason why I am recommending ESP 0W30 is that it is PAO/GTL/Ester based oil. It has HTHS above 3.5cP. Only reason why it doesn’t have LL04 is that it has but higher oxidation due to presence of esters and not % of Group III base stock that BMW wants (which is actually good). Available in Wal Mart.It's a 2014 Mini Countryman with the 1.6 liter N/A engine that calls for LL-01. I've been using Castrol Euro 5w-40 in that one, and Delvac 1 ESP 5w-40 in my deleted diesel Mercedes. Both cars are out of warranty, but we are planning to keep them long term so I'm more concerned with protection than anything, which is why I'm running 5w-40 in both. We live in Florida so winter starting is not an issue.
I've considered running the Castrol in both since it meets LL-01 and MB 229.5 but I'm not sure how that oil would do in a diesel. Also considered running the Delvac 1 in both, but again not sure how that oil would perform in a gasoline engine. I can keep buying two different oils but it would be nice to just have to stock one. I'm sure I'm overthinking this, but isn't that what this forum is for?![]()
