Fuel will be far less than 80ppm. Numerous UOA prove that. I use in Tiguan amd used in Atlas low SAPS oils and UOA proves that after 5k there is enough additives to do full 10k OCI. When we had higher sulphur levels, additives would be at min after 5K.
You can’t refine oil like that, one to produce certain fuel another not capable. Shell for example will buy fuel from oil refinery here in Denver, which is not theirs. But, it has to meet Shell standards. That refinery cannot just like that switch production between fuel for Shell and for Costco.
But here is the thing, I have no idea what is argument here. You know you can mix those oils, so not sure where we going. If you have enough oil to cover one engine with one approval, I would do that. If not, mix it.
