A bit long. But hope someone can help
Originally the car has alu liners. And it has a notorious reputation to crack in the cylinder liners and have total engine failure before 50000miles. Some are on their third engine
My car had the same problem at 36000 miles.
The new block BMW provides is now improved with steel liners instead (new block with krankshaft, rods, pistons, and pistonrings). And that is what I have just installed. Hopefully the notorious liner cracking problem is cured.
But BMW don’t reply back on what oil they recommend for the new upgraded engine they sell. Local BMW shop only say they fill 0W-30 (BMW LL-04 spec.) on every car. Both diesel and gasoline. And on older NA M-cars they fill 10W-60.
I don’t know if I like the new LL-04 oils. They perform well it looks like. But they also have saps and specs towards diesels and not so hard on the cat. And make them in some cases not superior to the LL-01 oils?
To me it seems like it’s better to go for LL-01 oil in my car?
The first miles I have used AMSoil break-in-oil. But what to use after the initial break in?
Specs:
-BMW 320si 2006
-Engine code: N45B20S (Yes, it’s an S in the end. Normally indicating it’s an M-car engine...)
Engine built specific for the WTCC races. 2600 road legal cars were sold to meet the homologation requirements to compete. But engine is far from that tuned as the real WTCC engine.
Engine was produced at the same place as they produce BMW Formula1 engines. And it’s a close tolerance engine.
-Car is used in Norway with cold winters.
-Sometime it may find its way to track days. And it will hit the rev limit on street also. I characterize my driving between moderate to hard 10% of the time. The rest 90% are half city traffic and half long distance drive (countryside and highway).
-Oil change about every 6-10000 miles.
-Run on 98 octane.
Oil spec in manual: LL-01 or LL-01FE 5W-30 or 5W-40. (More specific according to oilspecifications.org http://www.oilspecifications.org/bmw.php this means: BMW Longlife-01
Special BMW approval for fully synthetic long-life oil. Product meets ACEA A3/B3 and API: SJ/CD EC-II.)
When I look in the WTCC parts catalog I see that they recommend the Castrol TWS 10W-60 oil. But that engine only sees track use...and tuned to 310bhp...)
I have looked at the following oils:
-Penrite 10tenths Premium 0W-50 (0W-40 viscosity)(Non LL-01 approval)
Looking real good. But it only has BMW LL-98 rating. And my engine is under warranty for next 5 years. But it does have ACEA A3/B3 that equals to LL-01. And it has API SN/CF that surpasses LL-01? Did they not pay BMW to get it upgraded to LL-01, or do I miss something?
-Penrite HPR5 5W-40 LL-01
-Pennzoil Platinum Euro 5W-40 LL-01 (Back when LL-01 was the standard. Pennzoil platinum Euro 5W-30 seems to be listed by BMW to be approved option.)
-Valvoline SynPower (not extreme) 5W-40 LL-01
-Agip/Eni i-Sint 5W-40 LL-01
-AMSoil European 5W-40 LL-01
Also had a look at the following for consideration. But did not look as good as the abow:
-Purple API 5W-40 (ACEA A3/B3-04)
-Castrol Magnatec 5W-40 LL-01
-Castrol Edge 0W-40 LL-01
-Redline 5W-40 LL-01
-Gulf Formula GX 5W-40 LL-01
-Gulf 0W-40 Formula GX LL-01
-Mobil1 new life 0W-40 LL-01
-Liquid Molly Leichtlauf high tec 5W-40 LL-01
I’m thinking Castrol Edge 0W-40 LL-01 for the first 6-10000miles after the breake-in-oil. Then
Penrite HPR5 5W-40 or Pennzoil Platinum Euro 5W-40 LL-01 until warranty period is out.
Then after that Penrite 10tenths Premium 0W-50. If not in the meantime a new oil has emerged.
Please give inputs on my thoughts. Anything I need to reconsider? Should I go for a LL-04 instead? 0W-30 oil? Then what about track days? Switch to the Castrol TWS 10W-60 oil M-car oil for the track day?
I am confused
Specs:
-BMW 320si 2006
-Run on 98 octane.
I am confused
