Suggestions? Going in a Hyundai 1.6T. Use what the dealer uses? (QS Bulk 5w30)? Here is my apparent "choices" in Viscosity, but I know if goes way further than that.
As a Hyundai "enthusiast", if there even is such a thing, I can honestly tell, just don't. Don't use the dealer bulk oil. I did that once in 2019 in each of our Hyundais because I didn't have time to change it myself and the dealer refused to accept to bring my own oil (new policy). Up to that point I was running Mobil 1 Extended Performance 5w30 in both of our Hyundais. Well, the dealer claimed they put Pennzoil Platinum 5w30 in our vehicles, which turned out to be Quaker State Ultimate Durability, which in the end, after I managed to walk back in the service department with an advisor turned out to be a barrel of random 5W-20 that they were putting in all vehicles regardless of what they needed. But that's not the worst of it. After a few thousand miles I noticed the oil caps on both vehicles darkening, and then when I drained the oil, on my wife's 2017 SF 3.3L plastic housing there was varnish. Looking inside the valve cover with a camera, there was varnish there as well. Took several oil changes with Mobil 1 0W-40 and then Castrol 0W-40 and a bottle of Lubegard Engine Flush to get rid of all of it. I settled on Castrol 0W-40 because it stands up better to fuel dilution than Mobil 1 0W-40 in GDI engines.
So here is my recommendation to you:
The best ILSAC GF6-A oil for a turbo engine I know of is Castrol EDGE Extended Performance 5w30. It stands up really well to fuel dilution. Wanna go a bit thicker and with more additives? Castrol EDGE Euro 0W-40, you will love it, it stands up very well to fuel dilution as well.
There are other excellent oils out there as well like PUP, Mobil 1 Extended Performance, Quaker State Ultimate Durability, RTG, however, for your application I recommend Castrol. Don't waste your time with a 5W-40 like Castrol EDGE 5W-40, it's a Group III synthetic that's not as good as their 0W-40.
The Castrol EDGE Euro 5w30 is also a decent choice, however, the oils I mentioned above have updated formulations and additive packages. Throw a bottle of 15oz. Lubegard in there, but don't subtract the quantity from the oil, as the Lubegard oil additive carrier will be evaporated after the oil reaches 212F or above. If you have a fuel pump "tick tick tick", the Lubegard will quiet it down. The fuel pump runs on one of the camshafts, and it's noisy. It made a world of difference in my brother's brand new 2020 Sonata 2.5GDI engine, no more loud fuel pump ticking at idle after adding Lubegard.
I hope this helps.
