5w-30 for Turbo GDI
No. A sequence is gasoline engines, higher SAPS. B sequence are old diesel sequences. C is newer, Lower SAPS sequences (A3 and C3 are HTHS compatible, but differentiate in SAPS). E is commercial sequence.
A3 are more stringent sequence than A5. Castrol Edge 0W30, 0W40, Mobil 1 0W40 etc. are A3, and you ain't gonna find A5 oils offering protection, especially for turbo engines like those oils.
I know.
But they don't know. So, who cares. Use A5 or higher. Who cares how higher is defined!
Suggestions? Going in a Hyundai 1.6T. Use what the dealer uses? (QS Bulk 5w30)? Here is my apparent "choices" in Viscosity, but I know if goes way further than that.View attachment 42393
As a Hyundai "enthusiast", if there even is such a thing, I can honestly tell, just don't. Don't use the dealer bulk oil. I did that once in 2019 in each of our Hyundais because I didn't have time to change it myself and the dealer refused to accept to bring my own oil (new policy). Up to that point I was running Mobil 1 Extended Performance 5w30 in both of our Hyundais. Well, the dealer claimed they put Pennzoil Platinum 5w30 in our vehicles, which turned out to be Quaker State Ultimate Durability, which in the end, after I managed to walk back in the service department with an advisor turned out to be a barrel of random 5W-20 that they were putting in all vehicles regardless of what they needed. But that's not the worst of it. After a few thousand miles I noticed the oil caps on both vehicles darkening, and then when I drained the oil, on my wife's 2017 SF 3.3L plastic housing there was varnish. Looking inside the valve cover with a camera, there was varnish there as well. Took several oil changes with Mobil 1 0W-40 and then Castrol 0W-40 and a bottle of Lubegard Engine Flush to get rid of all of it. I settled on Castrol 0W-40 because it stands up better to fuel dilution than Mobil 1 0W-40 in GDI engines.
So here is my recommendation to you:
The best ILSAC GF6-A oil for a turbo engine I know of is Castrol EDGE Extended Performance 5w30. It stands up really well to fuel dilution. Wanna go a bit thicker and with more additives? Castrol EDGE Euro 0W-40, you will love it, it stands up very well to fuel dilution as well.
There are other excellent oils out there as well like PUP, Mobil 1 Extended Performance, Quaker State Ultimate Durability, RTG, however, for your application I recommend Castrol. Don't waste your time with a 5W-40 like Castrol EDGE 5W-40, it's a Group III synthetic that's not as good as their 0W-40.
The Castrol EDGE Euro 5w30 is also a decent choice, however, the oils I mentioned above have updated formulations and additive packages. Throw a bottle of 15oz. Lubegard in there, but don't subtract the quantity from the oil, as the Lubegard oil additive carrier will be evaporated after the oil reaches 212F or above. If you have a fuel pump "tick tick tick", the Lubegard will quiet it down. The fuel pump runs on one of the camshafts, and it's noisy. It made a world of difference in my brother's brand new 2020 Sonata 2.5GDI engine, no more loud fuel pump ticking at idle after adding Lubegard.
I hope this helps.
This stupid company still did not figured out that there is no such thing as ACEA A5 or above. Amazing!
Get Mobil 1 ESP 5W30 on sale at NAPA. You hardly can go better than that.
But wait, there is more! Hyundai really went down the "stupid" rabbit hole with their newer vehicles. For example, in their new offerings with the 2.5 and 3.5 TGDI they require you run 0W-30, API SP. The only oil that comes close to fulfilling that requirement and that you can find easily is Mobil 1 Advanced Fuel Economy 0W-30. Though it's not that great for turbo direct-injected engines that most will run on the cheapest available gasoline and do an oil change when they remember, so fuel dilution will continue to be an issue. Sorry, but Hyundai is not Toyota when it comes to engines.
The 2020 Sonata allows up to 10w30, with 0W-20 being the default recommendation. Well, Hyundai figured that fuel dilution is still an issue with their new Smartstream engines, so for the 1.6T they increased the oil capacity by half a quart in the manual without any physical changes to the motor, but, they made the only allowable motor oil 0W-20.
I wonder who creates the oil recommendations for North America at Hyundai because it's sure as $h1t not their engineers.
I have a higher output version of the 1.6T in my Elantra Sport. Right now, I'm using this oil in the Audi and Elantra in my signature.
Castrol Edge A3 Euro 5W30. Got it at Walmart. Used oil buckled in to be disposed of properly by taking it back to the Walmart Auto center.
Where is the car seat for your oil ?????
You slacker absent minded oil father....
can you explain this? How can you put in half a quart oil more without modifications?
I have found what they are describing with Subaru's FB25D direct injection engines as well as with Hyundai's GF4D GAMMA engine. The Subaru engine has a 5 quart oil sump with a 4.4 quart recommended fill, the Hyundai engine has a 4 litre (approx 4.23 quart) sump with a 3.5 recommended fill (plus 0.3 quarts in the oil filter).
I cannot say with certainty but I have a hypothesis that due to the fact that there are know issues with blowby, be it fuel dilution and/or carbon soot, that the extra sump capacity is allowed to accommodate the buildup of the blowby content.
Edit: I remember talk in the thread linked below about how piston ring gaps are increasing in direct injection engines and that is allowing for substantial amounts of blowby. I surmised that this is to decrease emissions by turning the crankcase into a dumpster as others have spoken about.
https://bobistheoilguy.com/forums/threads/ilsac-gf6-chain-wear-test.331413/post-5513786
On the theta-ii, they simply replaced the dipstick with new F/L dots and instant increase in oil capacity.
Thet is the key! Then, what else they don't know?
They don't know how to build an engine that doesn't seize and doesn't fuel dilute. Engineering too busy with dipstick R&D.
The only grade oil, as per the manual, for my 2021 Kia K5 is 0W20. It has the same 1.6 liter GDI turbo as the Sonata. Does the Sonata manual state that you can use a variety of grades with 0W20 the recommended grade?
For anyone who doesn’t know, what @Greasymechtech posted about the oil dipstick on Hyundai Theta II engine is correct.
When the Theta II’s started dropping like flies in winter time, Hyundai did a recall which consisted of a microphone connected to a Samsung tablet, and the microphone was inserted in or near (can’t remember) the dipstick tube. If your engine passed the microphone test, you were awarded a replacement Orange dipstick that increased the oil capacity when filling up to the Full mark.
when did the Mobil 1 Advanced Fuel Economy 0w30 became an oil that is not that great for TGDI engines?
Mobil 1™ 0w30 Advanced Fuel Economy
Applications​
Mobil 1™ 0w30 is recommended by ExxonMobil for all types of modern gasoline-powered vehicles, including high-performance turbocharged, supercharged, multi-valve fuel injected engines found in passenger cars, SUVs, light vans and light trucks.
• Mobil 1 0w30 is recommended by ExxonMobil for SAE 0W-30, 5w30 and 10w30 applications.
• Mobil 1 0w30 is recommended by ExxonMobil for extreme cold conditions to help deliver quick starts and fast lubrication.
• Mobil 1 0w30 is not recommended for 2-Cycle or aviation engines, unless specifically approved by the manufacturer.
Always check your owner's manual for the manufacturer's recommended oil viscosity grade, API service classification and any builder approval.
Specifications and Approvals​
This product has the following approvals:
GM Dexos1 Gen2
This product is recommended for use in applications requiring:
API CF
Ford WSS-M2C946-A
GM 4718M
GM 6094M
FORD WSS-M2C953-A
FORD WSS-M2C953-B1
FORD WSS-M2C929-A
FORD WSS-M2C963-A1
This product meets or exceeds the requirements of:
API SN
API SM
API SL
API SJ
ILSAC GF-6A
API SN PLUS
API SN Resource Conserving
API SN PLUS RESOURCE CONSERVING
API SP
API SP Resource Conserving
Properties and Specifications​
Property
GradeSAE 0W-30
Density @ 15.6 C, g/cm3, ASTM D40520.841
Kinematic Viscosity @ 100 C, mm2/s, ASTM D44511.5
Pour Point, °C, ASTM D97-42
Flash Point, Cleveland Open Cup, °C, ASTM D92226
I actually explained why it's not particularly great for Hyundai TGDI engines, not TGDI engines in general. Just re-read my comment again, please:
The FTC should put Cryslet/FCA/Stellantis on notice as well. For almost a decade now they're telling customers in the owner's manual that they need to use SOPUS motor oils otherwise their warranty coverage might be voided. Never mind the overpriced Mopar branded fluids. In some situations, it's so bad that you don't even know which overpriced Mopar fluid to buy, like for the **** BW44-44 transfer. Mine is a 2016 RAM 1500 and I don't even know which fluid to get, and the dealership isn't 100% sure, but I might void my warranty if I get the wrong one. I just got some Amsoil Multi-Vehicle ATF and called it a day. I would love for the FTC to put an end to this Mopar/SOPUS fluids nonsense.
