Originally Posted By: Ursae_Majoris
Wal-Mart has a patent on 5 qrt jugs, IIRC (BITOG discussion a while, while back). 5 Liter jugs are used as a way around it.
You are joking, right??
Yeah I think he is...
Isn't 5.1 Qts equivalent to 5 Litres?
This was the industry can use only one container which saves them money.
The 5+ qts jugs are great for those 4 qt systems that often need a topoff between OCI's or for those members that like to use the extra oil in small equipment.
I usually dump all the extra oil from a 5 quart jug into another container. Eventually you have enougth to do all the tractors, snowblowers, etc. LOL... Wonder what it is after I blend 20, 30, 40 weight oils. Oh well.
Hello, That's what I do. I was only kidding when I said I run my car (6.1 qt. capacity) low. To me oil is a product I buy at a $/qt. price. How it is bottled is of little difference to me. What is notable is the fact that some 5+ jugs are/were 5.1 qt. and others are/were 5.28. A pal and I came up with a name for our mixed, leftover oil. We call it "multi-weight". Kira
Originally Posted By: volk06
Why would you intentionally run it 1 quart low?
As long as the car is between the "Full" and "Add" lines are you OK for most vehicles.
I typically don't add oil until I hit the Add line myself....
The 2 cars I've had, actually do not recommend adding oil UNTIL you hit the "Add" line......likely due to the fact that you're better off (safer..) under-filling the engine, than OVER-filling the engine.....
I save a few empty 1 qt oil containers and dump any left over oil from a 5 QT jug into one (or more) to use for the next oil change (or for topping up, but none of my current vehicles need any oil between changes).
If you have a Walmart nearby, the cost savings with the 5 Qt jugs is significant. They even beat Costco's price per quart on Mobil 1 as Costco sells a case of 6 1 qt bottles.
But, what I like best about the 5 Qt jugs is they're the perfect container to dump the old oil into for recycling. Trying to refill 1 qt bottles without overflowing them is not worth the hassle.
