Originally Posted By: tom slick
It depends on the vehicle. many have the front driveline engaged all the time, shifting into 4wd only engages the hubs or similar mechanism. still a good idea to occasionally make sure everything works before you need it though.
Its an 08 Liberty with Select Trac II. In 4 H it only engages when needed, so technically it can be driven in that mode all the time. I bought it with that system so if my wife needed 4 WD and forgot to switch it back to 2H it wouldn't ruin anything on dry pavement. In 4L its engaged full time, that's why I put it in 4L when backing into the garage. I figure it will get all parts lubed up.
I will be using 4L to drive up ramps to change oil next OC, it has a lot of torque in 4L.
Thanks for the replies!
Frank D
