4L60E valve body reconditioning.
Anybody really happy with a service that does a quality job with vac testing reaming/repair and updates. Found a guy and was wondering if $450 was a decent number.
Whats the quality of Sonnax's kits- I love Sonnax parts but have read the VB's don't measure up to there own spec. Who buy the tp HD model ?
Sonnax like any other large corporation uses cheap labor & the VB's are tested on a test stand in a pass/fail. Not vacuum tested like we do in the field.
HD is for the Overrun Clutch it stay on in D3-1st & D3-2nd to protect the forward sprag, If you're not abusing the unit.....Not a need.
My plan was to cheap out on solonoids and just replace the EPC, buddy wants ALL replaced and harness- considering the age alone I'm ok with this. Is Rostra decent not a fan of ACD these days, GM Genuine?
Things get expensive fast for that harness if you try to move beyond Rostra.
Are these eps connector interchangeable?
The weight of the vehicle along with Traction has a lot to do with it.
I have one of my 4L65's in a 2001 Tahoe, Stroked 408 LS that puts down 600 foot pounds.
It has a Sonnax Smart Input Drum & a 300M output shaft & is holding up well (Over 200 1/4 mile passes)
In a heavy vehicle like this.....It's near the limit of what a 4L60/65 will reliably handle.
Other than the above mentioned extreme example, where would you use (or not) the Sonnax reaction shaft. If I used all Sonnax parts this would be a $10k trans ;) Heavy vehicle 4x4 383. I'm thinking yes I should invest.
