Going over the brake system on my recently purchased 92 Toyota Pickup 2wd, and I found that the load sensing proportioning valve assembly is weeping, so it's only going to get worse. Thought about doing a bypass on it, but I am going to buy the Toyota part, and fix it right. That part is ridiculously expensive, and it cost me $173 total. Supposedly, they can't be rebuilt.
Read over a service manual for a 93 Pickup like my 92, and it goes into detail about using two pressure gauges, and all that mess. But it does say that the pressure can be set to the rear brakes initially, and be close by measuring the distance between shackle and the spring. Mine would be 3.07 inches or 78 mm.
Here is what I am not clear about, and this is my first time around with one of these valves.
(b) Position the valve body so that the valve piston lightly contacts the load sensing spring. (c) Tighten the valve body mounting nuts.
I think I understand what it means, but there is dust boot that covers the valve piston, so I am guessing that the boot has to be pulled down out of the way, so I can see the valve piston.
Anyway, let me know what you guys think about all this mess I got myself into again!
