Caulk 8HP Thermal Bypass Valve Installation
Indiana
Caulk 8HP Thermal By-Pass Valve Installed!
My 2022 RAM 1500 has a “not wonderful” transmissionmission heater that assists in keeping the transmissionmission fluid too hot for my liking (185 deg F to 200 deg F). RAM identifies this Mopar 68463479AA Transmission Heater.
RAM 1500 stories abound about the thermostat sticking open and not fully closing after a period of use. Pictures in this post will also attempt to explain why the thermostat in the transmissionmission heater part stick(i.e. “fails”). When it does stick, the end user will generally experience a “slow creep” upwards in transmissionmission fluid temperature over time 👎🏻. Obviously, this slow temperature creep of the ATF is not beneficial for those of us who desire to run a RAM1500 (also some Jeeps) 250,000 miles to 500,000 miles utilizing the original transmissionmission.
As such, I researched some other forums for my RAM and learned of a “thermal bypass valve” parts kit. Many RAM enthusiasts pointed myself in the direction of the Caulk 8HP Thermal Bypass Valve that is designed specifically for the ZF 8HP70 and ZF 8HP75 8-speed automatic transmissionmissions.
Caulk Thermal Bypass Valve
I read the manufacturer’s claims and decided I would take an $80 “gamble” on the thermal bypass valve with a new machined aluminum cap (replacing a plastic OEM ZF thermostat valve cap).
In reality, this valve is really a "delete" option that simply prevents the coolant loop from cycling coolant from the cooling system’s radiator back to a small liquid-to-liquid heat exchanger mounted on the side of transmissionmission (driver’s side).
After the thermal bypass valve thermostat guts are installed into the body of the transmissionmission heater assembly, transmissionmission fluid is sent to the transmissionmission cooler 100% of the time the motor is running. Post-modification, the transmissionmission temperature rises much more slowly and keeps normal transmissionmission fluid temperatures in the 140 deg F to 165 deg F range.
The idea here is to keep the transmissionmission fluid cooler when towing and driving 70+ mph (with and without towing trailer weight).
Hopefully this results in an extended transmissionmission service life and less lubricity loss as the transmissionmission fluid ages and is used/“burnt”over time). I shall see in the future, won’t I?
For those not desiring to read through the entire thread here, I will simply say “YES” ; the Caulk Thermal Bypass Valve does indeed work as advertised. I am impressed that this product actually performs as advertised.
The top two pieces in the above picture are the formal “kit.”
Below that, second row is the OEM pin and OEM snap ring. These two parts are reused.
On the bottom row are the original thermostat plunger, springs, and plastic cap. Over time, the plastic cap becomes worn from the brass of the original transmissionmission heater thermostat. Eventually the brass disc portion of this OEM part sticks into the “fingers” of the end of the OEM plastic cap. The net effect is that the thermostat cannot fully close (retract) from the plastic. At that point, you are continually cycling coolant into the transmission heat exchanger and it keeps heating.
Not a good thing for those of us that haul & tow heavy loads as well as not good for general summer driving.
Getting to the OEM Transmission Heater is actually the hard part of this modification. Installing the actual bypass valve assembly is pretty easy (save snap ring removal).
If a 4WD RAM 1500 like mine, disconnection of the front driveshaft at the differential joint is necessary. Four 15mm bolts and it pops out enough to advance to the next step.
Next, the transmission brake cable mount must be removed and pushed down and out if the way. You will need a T40 Torx bit and a smaller ratchet in order to remove two T-40 Torx head mounting screws and pop the cable off of the pin of the actuator.
After the mounting screws snd cable ate removed, access to the transmission heater’s plastic black cap thermostat cap and snap ring is possible. Remove the snap ring and the plastic cap and the thermostat’s internals will come out (along with a small quantity of transmission fluid. If replacing the plastic cap, just drive a small wood screw into the plastic cap and pull. Out she will come.
Assemble the new bypass valve per instructions with the thermostat’s original pin. Insert the assembly into the cylindrical hole and push in with the new aluminum cap (or plastic cap if you are reusing it).
Here is a picture with RAM thermostatic valve removed from the mounting component of tge transmission heater assembly.
And after the thermal bypass valve is installed, pushed into place with the cap (new aluminum cap designed for this kit) and secured with the OEM snap ring.
Make absolutely sure your snap ring is seated gully into the groove before you begin reattachment of the cable bracket mount, cable, and front driveshaft!
Your modified transmission heater assembly and the cap/snap ring should look like the follieing picture when i stalled correctly.
Reattach your cable mount with the T40 torx screws, push on the cable, and reattach the front driveshaft to the differential jojnt with the 15mm hex headbolts. Add a dab of blue thread locker on these bolts and re-torque to spec.
Complete 8HP Thermal Bypass Installation Instructions
Violá! You are finished. Now grab a cold beverage, start and drive your RAM 1500 as fast and long as you wish. Mine has never broken 162 deg F transmission fluid temperature to date. It operates perfectly. Happy happy happy 😊.
Performance Test & Check
After driving 50+ miles one way to work (80 mph), the highest transmission temperature I could create was 154 deg F. (ambient air temperature through my radiator and transmission cooler was 60 deg F over multiple trips to work).
I am quite pleased.
I did the same, before I had transmission temps reaching as high as 220 degrees on my summer trips, after install, no higher than 160 degrees, yes I'm happy and it works.
I installed the caulk bypass last summer along with the PPE pan, and several fluid changes replacing with Amsoil. I did notice in summer getting up into the mid 180's or so, but I didn't monitor too closely.
The heavy duty Rams with the same transmission don't have that silly transmission heater/exchange which tells us it's not there to make these units last longer.
I have the little device on my garage shelf but have yet to install it. Honestly these ZF's run super cool most of the time, even towing for hours on end I've yet to see > 180F.
Gggh
My RAM used to be that way as well,,, then one day it wasn’t. At least you know that you have a modification part that works if you RAM’s transmission fluid temperature starts climbing during normal operation. 😉👍🏻
Gggh
Exactly. When I bought it Jesse wasn't sure if he was going to be making them anymore so I snatched one up!
