Whats the quality of Sonnax's kits- I love Sonnax parts but have read the VB's don't measure up to there own spec. Who buy the tp HD model ?
They are not, That's the earlier design '93-'02, 2003 & up is different.Are these eps connector interchangeable?View attachment 349575View attachment 349576
Have you had an opportunity to look and install this Sonnax kit?
https://www.sonnax.com/parts/5628-input-housing-forward-sleeve-kit
These harnesses are killing me.They are not, That's the earlier design '93-'02, 2003 & up is different.
You can run a early style PC Solenoid on any 4L60E & is arguably a better Solenoid.
Is this forced induction territory- at what point does the 4L80E make more sense?Installed several, Not needed until you cross over 450 pound feet of torque.
Other than the above mentioned extreme example, where would you use (or not) the Sonnax reaction shaft. If I used all Sonnax parts this would be a $10k transThe weight of the vehicle along with Traction has a lot to do with it.
I have one of my 4L65's in a 2001 Tahoe, Stroked 408 LS that puts down 600 foot pounds.
It has a Sonnax Smart Input Drum & a 300M output shaft & is holding up well (Over 200 1/4 mile passes)
In a heavy vehicle like this.....It's near the limit of what a 4L60/65 will reliably handle.
