I use Pennzoil Ultra Platium 5w30 in my 2019 TRD OffRoad with 107,000 miles in North Carolina and it’s been great!
Pros and cons to both. 2GR-FKS has issues with valve seats and timing cover leaks (as usual).I love this motor. An easy 25 mpg with over 300 hp. Went with Mobil 1 Extended Performance 0w20 while under warranty and now Mobil 1 5w30 Extended Performance for most of the year. Will run the 0-20 for the winter oci. Wife does 20,000 a year in her Highlander. I struggle with buying the new 2.5 turbo that replaced it that gets worse gas mileage by many accounts. Maybe with the recent epa rollbacks Toyota will bring it back.
2.4 Turbo is too new to say, but from a driveability standpoint, it has a more usable power band and drives significantly better in most situations.
I think the failures are mostly the Tacoma's and some early Highlanders. Otherwise after 2020, besides the timing cover leak they are great. As for power band, drive it in Sport mode if available. It does makes a difference.I have been seeing more and more 2GR-FKS failures popping up lately, kinda odd. After having two in a Tacoma and now the new turbo 4 engine, they both have their ups and downs. The V6 after 3K RPM's just pulls to the redline strong. The 2.4T has everything low to about 4Kish and just falls off? But for stop/go it definitely is better. Fuel mileage is a crap shoot. Stock small 245 tires it was pulling 25mpg consistently. Now with slightly bigger and heavier tires it's back down to 3rd gen range. If you romp on it and keep it in boost, I've seen mine get down to 14...
Sorry for the delay, attached is Blackstone report for this O&F change with HPL Premium PCO (Not the plus) 0w-30. Based on feedback and cost I am going to try a different lab with the next change (~8k miles coming up in Oct)Please do post used oil analysis, I feel like we're lacking a database here for Tacoma's. I'm presently running a test on my own truck between different differential and transfer case lubes. My last drain of the three is in the used oil analysis section
Highly recommend a tune, it will be a brand new truck. I've been tuned since the truck has had ~8000kms with a few different ones.
Full disclosure, I am a YotaWerx tuner now.
Yeah I'd look at Oil Analyzers for gas chromatography for fuel dilution.Sorry for the delay, attached is Blackstone report for this O&F change with HPL Premium PCO (Not the plus) 0w-30. Based on feedback and cost I am going to try a different lab with the next change (~8k miles coming up in Oct)
