- Joined
- Jul 22, 2022
- Messages
- 830
No, it's not really time related.That barrier requires oil to stay there for more than 3 months?
So mileage related, oil should stay there till 4000 miles? My TBN was 6.1 when I changed the oil so I should wait at least to 4.0 TBN?No, it's not really time related.
Get a fumoto valve so you aren't excessively wearing out your oil pan threads.
NO! Or at least be very cautious going that route. For a period I did a lot of serious off roading, and I did a lot with a group of regulars. Among that group, several used those valves (myself included), and in a couple of instances the rough terrain got in the way of the valve. In most instances in such terrain a spotter was used, and it could be seen by the observer that the valve was a point of impact with the ground. In one instance the valve was ripped out of the oil pan ... damage followed. Knowing that, and seeing the issue first hand, I stopped using the valve. YMMV, but be cautious.Will do. Thank you!
It takes a combination of mileage, time and hopefully getting oil up to operating temp. The AW additives will lay down a film or plate like barrier. How would you know when your TBN is at 4 unless of course you do a used oil analysis? Your TBN was still like new at 6.1. Like I previously mentioned. if you're worried about fuel dilutionSo mileage related, oil should stay there till 4000 miles? My TBN was 6.1 when I changed the oil so I should wait at least to 4.0 TBN?
My TBN was 6.1 after 2,500 miles, Blackstone report says, I sent a sample to them. Oil was Pennzoil Ultra Platinum 0W-20. New oil might have a TBN of 10 or 9?It takes a combination of mileage, time and hopefully getting oil up to operating temp. The AW additives will lay down a film or plate like barrier. How would you know when your TBN is at 4 unless of course you do a used oil analysis? Your TBN was still like new at 6.1. Like I previously mentioned. if you're worried about fuel dilution
you could bump up to a higher grade of oil which may be helpful also.
I don't believe the starting TBN is that high on that oil.My TBN was 6.1 after 2,500 miles, Blackstone report says, I sent a sample to them. Oil was Pennzoil Ultra Platinum 0W-20. New oil might have a TBN of 10 or 9?
I wouldn't say stupid, but this is obviously excessive. A 5K OCI is excessive in most cases, but it isn't stupid either.Guys, I love my Jeep and oil change takes 20 minutes and $35. So I have decided to change the oil every 2500 miles. Oil goes in nice and clean and comes out nice and clean. Am I stupid?
Is there a particular oil that has TBN of like 15? I could run that oil and then change it every 7500 miles?I don't believe the starting TBN is that high on that oil.
I would say between 7.5 and 8 is more like it .
I bought so much oil recently I wanted to do like every 2000-3000 also on my new car. I want to see which oil it likes the most. Also going to compare oil samples and cold start/idling noiseGuys, I love my Jeep and oil change takes 20 minutes and $35. So I have decided to change the oil every 2500 miles. Oil goes in nice and clean and comes out nice and clean. Am I stupid?
Don't know about 15 TBN but 12 is around the highest number I've heard of and they would be long drain oils, HPL and Amsoil come to mind. With your apparent mindset I'd say your a long way from going anywhere close to the mileage that those oils offer. Good luck.Is there a particular oil that has TBN of like 15? I could run that oil and then change it every 7500 miles?
I do 5k OCI on my Jeep - filter 10k - Fram Ultra - I think the less you touch that filter housing the better. Have changed Xfer case twice and differentials 2/3 times bcs they had visible shedding early on as experienced by others … 4 years old at 34K - a few hundred miles in 4WD - I might do the coolant at 5 years old…Is there a particular oil that has TBN of like 15? I could run that oil and then change it every 7500 miles?
I am very careful with the oil filter housing, I do 17 lb foot, manual says 18I do 5k OCI on my Jeep - filter 10k - Fram Ultra - I think the less you touch that filter housing the better. Have changed Xfer case twice and differentials 2/3 times bcs they had visible shedding early on as experienced by others … 4 years old at 34K - a few hundred miles in 4WD - I might do the coolant at 5 years old…
The port injected Pentastar does not have a reputation for fuel dilution - but BS has a mediocre reputation for measuring that with the methods employed …
I was mainly using 30’s and then 0W40 - after a bit I assumed it was causing an oil pressure pattern change. Went back to 0W20 and it’s still doing it (in/out of high pump stage at low load/RPM)*I'm moving to 6 month changes on my Civic, because 90% of my driving is short trip in the city. I also enjoy changing oil. Gonna change the filter every other change. And moving from 0W-20 to 5w30, due to fuel dilution.
