Jeep Junkie
- Joined
- Oct 16, 2024
- Messages
- 78
I love my lil Jeep. I have seen 3.6L Pentastars rocking 500k miles on Pacificas, Grand Caravans and Rams. I want to join at least the 300k mile club
There is a point of diminishing returns though when it comes to doing frequent oil changes. Why do you feel like 2500 miles is what is needed to get to 500k? It’s not as if 2.5k changes will double the engine life compared to 5k changes. It’s very likely that your engine would last just as long with 5-6k oil changes actually. (And even then there is no guarantee that it will hit 500k no matter what you do, as there are a lot of factors that get an engine to last that long)I offroad a ton, and I want my Jeep to last 500,000 miles
Did a Blackstone at 2,500 miles and TBN came at 6.1 but fuel at 1.5%. Pennzoil Ultra Platinum 0W-20Maybe do a uoa and see what comes of it
Factors for instance coolant? I am thinking of changing my coolant every 25,000 miles way before it gets acidic and eats all the plastic in the engine bay. I saw Car Care Nut and a 200 Series Landcruiser showed up at his shop with a blown 5.7L V8 because the guy didn't change his coolant regularly.There is a point of diminishing returns though when it comes to doing frequent oil changes. Why do you feel like 2500 miles is what is needed to get to 500k? It’s not as if 2.5k changes will double the engine life compared to 5k changes. It’s very likely that your engine would last just as long with 5-6k oil changes actually. (And even then there is no guarantee that it will hit 500k no matter what you do, as there are a lot of factors that get an engine to last that long)
Will do. Thank you!Get a fumoto valve so you aren't wearing out your oil pan threads.
Coolant, when it comes time to flush the FCA purple, there are better coolants out there. I recommend Fleet Final Charge Pro, but there are other good coolants that will go 5 years without breaking a sweat.Factors for instance coolant? I am thinking of changing my coolant every 25,000 miles way before it gets acidic and eats all the plastic in the engine bay. I saw Car Care Nut and a 200 Series Landcruiser showed up at his shop with a blown 5.7L V8 because the guy didn't change his coolant regularly.
I am on a mission to become a very high mileage Wranglery
Stupid, no. Overly cautious, yes. Your change interval is way overkill. You could EASILY go 6 months/ 4000 miles. An oil analysis can give you a good idea on a good interval.Guys, I love my Jeep and oil change takes 20 minutes and $35. So I have decided to change the oil every 2500 miles. Oil goes in nice and clean and comes out nice and clean. Am I stupid?
Should have bought a Toyota, not a Jeep !I offroad a ton, and I want my Jeep to last 500,000 miles
Toyota offroaders have IFS, I wanted more flex in the front axleShould have bought a Toyota, not a Jeep !![]()
Is 1.5% fuel sitting in the oil not bad?Stupid, no. Overly cautious, yes. Your change interval is way overkill. You could EASILY go 6 months/ 4000 miles. An oil analysis can give you a good idea on a good interval.
Changing oil that often won't make it any easier to get to that 1/2 million mile mark.I offroad a ton, and I want my Jeep to last 500,000 miles
TCB?Changing oil that often won't make it any easier to get to that 1/2 million mile mark.
By the time the TCB gets laid down you're
wiping it away, not to speak of being wasteful. 5k mile oil changes is what I'd suggest.
Tribo chemical barrierTCB?
That barrier requires oil to stay there for more than 3 months?Tribo chemical barrier
To answer your question, I’m inclined to say yes. Oil changes every 2500 miles, coolant changes every 25K.Guys, I love my Jeep and oil change takes 20 minutes and $35. So I have decided to change the oil every 2500 miles. Oil goes in nice and clean and comes out nice and clean. Am I stupid?
