21 Subaru Ascent - M1 EP 0w20
Sioux City
What do you guys think about these oil analysis’s?
I’m not good at breaking down whether the UOA is “good or bad”. To me it looks like the FA24DIT is pretty hard on oil based on cST Vis being so low. I changed the FF at about 1000 miles and I did not do a UOA on that. M1 EP 0w20 was used for both of these oil changes and I’ll be do soon for another in a month or 2.
Are you using any fuel additive?
I have used Gumout All-In-One and Techron once each. I can’t recall the mileage at which I used them, but I believe it would have been a few tanks before the oil change on each and generally before a long road trip. I wouldn’t think that would have a huge affect on the oil unless I was using it more frequently. But I could be wrong.
We don’t tow anything or have heavy loads. Since it’s primarily my wife’s car, it doesn’t get driven very hard either, but she does use the remote start a lot in the winter. I’ll give it the beans whenever I drive it, but mainly just on the on ramp. You know, like an Italian tune-up. Lol
That engine destroys the KV100 of any oil it touches. And yes Subaru does approve of 0w30 usage in this engine per an email that I can refer to.
What is a good 0w30? I have considered it based on how “thin” it gets on the UOA. I have none available locally and haven’t seen much online since it isn’t that common. I think a 0w40 would be a bit excessive. From UOA’s on other vehicles of 5w30 I would expect many 5w30’s to breakdown pretty quick in this engine as well.
Not much to see….still breaking in. Check back in 50k.
Is this normal to see oil breakdown this much in a new engine? This is the first car I have done UOA’s on.
Mobil 1 makes a 0w30 that you may be able to find at Walmart, Fram makes a 0w30 that is available at Advance Auto Parts. Those are your least expensive options, there are many 0w30 oils produced at a boutique price point. Whatever you decide I would recommend getting it in a 5 quart jug quantity and simply dumping it all in during an oil change.
5w30 options are seemingly endless and more easily acquired at a lower price point, they should work just as well so long as you're not in extremely cold environment.
I did see 0w30 M1 AFE at Walmart once, but lately I haven’t seen it, let alone many oil options since a lot is out of stock. I’ve never considered Fram oil, I haven’t seen much about it here to know if it’s any good.
Since I live in Iowa our winters get pretty cold. This year so far has been mild. But in the past it’s common for temps to average 10F for a couple months and sometimes there are weeks where the high barely reaches above 0F. I would feel better about a 0w30 vs 5w30 personally. I’ve seen some on Ascent forums using 5w30, but they are usually in AZ or other hot climates.
I live in Wisconsin and previously lived in Omaha, anywhere in Iowa can get away with using a 5w30 even in the coldest winter temperatures you can expect. I have had good results with Valvoline but aside from that I would consider Castrol Edge (or EP) and Citgo as well.
Ahh, you were in my neck of the woods! I’m in Sioux City, so you know exactly how frigid it can be.
I’ve considered trying Schaeffers 9000 0w20 since it has a VI of 174, pretty darn high and I can get it locally. I also looked at Idemitsu 0w20 since it is a Japanese oil and pretty reasonably priced. Though I just looked at Walmarts website and it looks like 0w30 M1 AFE is available at one of my stores. I’ll have to check to see if it’s actually there. I haven’t looked into Valvoline or Citgo.
In my Tacoma (4.0L) I use Castro Edge 0w40 euro and it’s always treated me well, though I’ve never done a UOA on that truck.
use a 30 grade and maybe even a 40 during summer roadtrip season like i used to do until going to a 40 entirely. That engine is hard on the oil. sheared it a lot. i wouldn't be afraid to use an sn plus or sp rated 40 grade either.
Sioux City, home of the Muskies (I'm a Lancers fan myself).
Schaffers makes GREAT oil, if you are already entertaining the purchasing of their products I would go ahead and go with them as I know that they are rock solid 👍
Welp, found some M1 AFE 0w30 at the old Walmart, picked up the last 3 jugs which is good for 3 OCI’s. If it doesn’t like it, then I’ll try some Schaeffers 0w20 and use the 0w30 in my Tacoma. I think the 0w30 will do just fine in the Ascent as it seems like this engine like to tear up the oil. I’ll post up results when I get the oil analyzed. I currently have 0w20 EP in currently, so the next UOA will represent that as well.
It’s kinda hard to make any reasonable analysis of this report since the engine still seems to be shedding quite a bit of material and it needs to be FLUSHED OUT first, before you can determine if the 0w20 is too thin.
From what it sounds like, based on the typical driving conditions, it should be just fine but there’s nothing wrong with bumping up to a solid 5w30 or even thicker simply to have more leeway in viscosity to account for extra idling, fuel dilution, etc. I think it’s silly to allow for a sheared down 0w10 to “protect” your engine.
Besides, any el cheapo synthetic is rated for -30F pour point, so there’s really nothing to worry about and only benefits of extra thickness for more cushion.
Mobil’s 0w30 fuel saver (which is what I think you bought) starts out at the bottom of the 30 scale and will quickly thin out into the 20s so you’re basically right back where you started.
If you want to stay with 20s, you need a very strong and durable brand then, with approved certifications from Mercedes, BMW, Porsche, etc on the bottle.
I have a collection of UOA data on this specific engine on my Subaru enthusiast website and my personal assessment/recommendation is that no matter what motor oil you choose to use it is best to follow Subaru's severe service schedule which calls for changing the oil every 3000 miles.
I missed this reply, my bad. I'm definitely ok with stepping up one grade to a 30w but I'm reluctant to step up to a 40w, especially this early in the vehicles life. As the get closer to 100k, maybe so. But judging off my use, we won't hit 100k for another 10yrs or so. Our previous car was a 12 Fusion that we sold when we got this in Nov 2020 and it had 85k-ish when we sold it and our driving habits really haven't changed much.
I don't think this engine is used outside of North America but I do recall the FA20DIT has been used for quite a while across the world. In other countries that engine is spec'd for 5w30 or with sever duty 0w40/5w40 and many nerds like us use 5w30 in that engine, though I don't think it's quite as hard on the oil like the FA24DIT has shown to be. While the FA24DIT is based on the same architecture, nobody has gone deep enough to see that all the clearances and other factors are the same. You could argue that bearing clearances can't really get any tighter than they currently are, there are other areas of the engine that theoretically could be affected.
To counter that though, the Ascent owners manual does state that "If 0W-20 synthetic oil is not available, 5W-30 conventional oil may be used if replenishment is needed but should be changed to 0W-20 synthetic oil at the next oil change". Also there is another note that state: "Engine oil viscosity (thickness) affects fuel economy. Oils of lower viscosity provide better fuel economy. However, in hot weather, oil of higher viscosity is required to properly lubricate the engine." So one would assume that an energy resource conserving 0w30 should be just fine. Also some in hot areas use 5w30 in the Outbacks and Ascents with this engine.
That's why I posted this as I'm not very knowledgeable when it comes to deciphering UOA's. I know this engine is still "breaking in" but I haven't seen many UOA's where a 0w20 has sheared down to essentially a 16wt. I've seen FF 0w20 on cars with over 5-10k where the 100c Vis is still at 7.00 or higher. I agree that it's odd how Subaru expects 0w20 to last 6k/6mo (OM Recommendation) miles in any circumstances. I certainly wouldn't consider our use as "severe service" that would justify 3k mile OCI's, generally I stick to 5k OCI's which I'll be changing oil again around 15K which should be 4-6wks from now. It's gently driven most of the time, in the winter it is idled for extended periods for warm-up but I wouldn't consider it excessive as Subaru remote start only allows 2 10min intervals, long road trips are usually 80mph, sometimes 85mph on the interstate but in IA, SD and NE it's small rolling hills with no large elevation changes and our city isn't large enough to consider long periods of stop and go IMO.
I agree that stepping up to a good 5w30 should be no issue either. I just prefer a 0wXX for piece of mind in our climate. I do recall that Pennzoil Platinum is a pretty tough oil and tends to be on the thinner side of a 5w30, so it would be a good choice in my eyes if the 0w30 M1 AFE doesn't pan out.
The thing about M1 0w30 AFE is that there is only 1 or 2 VOA's on it that I have seen and I haven't found a single UOA. I've tried searching but didn't come up with anything. I prefer off the shelf oils vs boutique oils I have to order online. I like to support local businesses (though Walmart is hardly what I consider local), I like to just go get it when I need/want it and generally boutique oils are considerably more expensive. Outside of Schaeffers 0w20 (VI 174 and usually lots of Moly) and M1 EP 0w20 (VI 173), I don't know if there are many boutique oils that match or better that. M1 AFE 0w30 has a VI of 166, which isn't as good as the 0w20's but I doubt it will shear down to a 16wt in 5k. Only one way to find out though. The only reason I don't consider Schaeffers a boutique oil in my case is that I can get it locally for a reasonable price. I have looked into Idemistu 0w20 as well, but it's spec sheet doesn't indicate that it would perform any better. If you know of any other 0w20's with that may hold up better, I'm all ears depending on the price of course.
I don't think I have heard of that site before. Do you have a link?
Usually the VI index being high is because of higher amounts of Viscosity improvers use in the oil.
40 grade sounds scary but that engine sheared a 20 grade into near 0w-8 range and a 40 grade that's kv100 13 cst will probably end up being 10cst which is a 30 grade. a 30 would end up being a 20.
a 0w-20 at 100f is gonna be like 50cst which is almost 3x the thickness of 20w-50 when hot but how does the engine sound on a cold start? nice and quiet. Once its hot it sounds like a spray paint can.
