Appreciate the feedback. To answer some questions / clarify:
- Regarding extended use, no, I pretty much stick to around 3k OCI especially given my heavy foot and how high strung this motor is (turbo, direct injected, 22psi factory)
- Using OEM honda oil filter, always.
- Prior oil right before this was actually 0w20 OEM honda (got a free oil change at the dealership), and not the amsoil 0w20 SS. I later found out that dealership oil change used synthetic blend and dumped it right away.
- While many 'normal' Honda turbo engines such as the 1.5T have fuel dilution issues, i don't believe this motor does (welcome any evidence counter to that however). Looking at my report, you can see the relatively high flashpoint as well.
- Replaced with Mobil 1 ESP 0w30 based on my research for a stout C40 spec oil + colder temps that will come during winter time. I may end up running this OCI a bit longer just due to me being lazy and waiting for spring before doing another oil change..
- Overall still happy with wear, and I do believe staying at a 30w vs 20w is probably more for peace of mind than anything. If I was tracking this car (which i'm not), I would def. stick to a 30 or even 40w. For street usage however, I think a light 30w or stout 20w seems right, but welcome discussion here!
