2025 Ram 1500 SST Engine Tear Down
THATS why i will keep my 2011 FRONTY!!! anything newer will be more costly to repair!!!
What a disaster. To change a darn valve spring you gotta put c4 under it and blow half the truck into space just to turn a bolt you couldn't get to. I think I'll keep my 2003 forever.
That may be possible in Texas, but here in the Midwest where they salt roads like margarita rims, you’d have had a pile of iron oxide and then the engine block and trans in your driveway. Like every other Ram of that era. The Cummins trucks were a 500k engine in a body that may last 90k 😳
But is it? Do you see anyplace for push rods going to the head? It’s an DOHC engine!
So??
Dual row chains on I6 engines can last more hundreds of thousands of miles than anyone will ever care…
Is raising the cab actually necessary or is it what the book says? From what I have read you don't need to pull the cab to remove the 6.7 head.
Thinking it may be a production line require related to engine / transmission assemblies mating process.
That's what I thought too, but I'm not buying it. You've got all the room and all the fixturing in the world to line up the engine and trans in the factory, there's still no way you need those studs to be that long.
Right and if they can save 10 cents a stud, they would. They didn't spec that length unless it is for a purpose.
