You can safely use it at -30° C.I would not be using 5w40 at that temperature, nor 20 below.
Which trim level do you have?My only complaint with my 2022 is the harsh ride. They are very stiff and will jolt and jostle your body over bumps. Loaded up, they smooth right out. My later model Ram 1500s spoiled me with respect to ride. Those rode like a big old Buick.
My 2012 Xterra same engine, very solid built suv that will go anywhere, I’m looking to swap the M226 locking rear from the Pro4x model but honestly the forestry roads I take for trout fishing don’t require itI have a 2012 Pro-X 4WD in Daytona Blue with the 4.0L engine. I use synthetic 10W30 in summer and 5W30 in winter.
Mine has the LS differential and I have to have it because my fishing and hunting areas often have thick mud (summer) or snow (winter).My 2012 Xterra same engine, very solid built suv that will go anywhere, I’m looking to swap the M226 locking rear from the Pro4x model but honestly the forestry roads I take for trout fishing don’t require it
S-model crew cab, short bed 4x4 with 16" steel wheels. I also have a set of 17" SV model alloys that I run on it.Which trim level do you have?
I drove a ProX as a rental and remember it riding surprisingly well for a truck.
I’m currently in the market for a midsize truck and have narrowed it down to the Frontier Pro4X or one of the Colorado/Canyon trims.
My 2026 long bed crew cab is nice. Turning radius is what it is, not been an issue for me. It's not a sports car. Rides nice and quiet. Much better than my 78 Datsun King Cab and my 84 4x4 Nissan pk did. The Hankook tires need to be re-balanced and aren't the best riding tire, but it's not too bad. Certainly not worth buying tires until I wear these out. I like this truck.The 2022+ are exactly like the 2nd gens in this regard. Turning radius isn't horrible until you get to the crew cab, long bed/wheel based models. With those, it's comically horrendous. Crew cab, long beds are very rare. Most are short beds.
Steering is a bit stiff on the 2022+ and they still use old school hydraulic rack/pinion which is nice.
I'm following The Oil Geek's break procedure. Change at 500, 1500, 3500, 5000. No filter change until 5000. He's cut open the filters he has used so far. No need for a change.Hey guys,
For your viewing pleasure. Some sparkles but not bad. Nothing notable in the can that I could see. Honestly, it’s what you can’t see that I am more concerned about. I went with the Puralator Boss filter. The inside of the media was clean. OEM filter seems OK, but not great. I wonder what the efficiency rating is.
This is why I do my first OCI very early, actually only 336 miles. I usually wait until 500 or so but I was bored today. Next one will be at 1500 miles, then every 5k after that. She also got a magnetic drain plug.
