2024 Frontier 3.8 - New Addition
My only complaint with my 2022 is the harsh ride. They are very stiff and will jolt and jostle your body over bumps. Loaded up, they smooth right out. My later model Ram 1500s spoiled me with respect to ride. Those rode like a big old Buick.
Which trim level do you have?
I drove a ProX as a rental and remember it riding surprisingly well for a truck.
I’m currently in the market for a midsize truck and have narrowed it down to the Frontier Pro4X or one of the Colorado/Canyon trims.
I have a 2012 Pro-X 4WD in Daytona Blue with the 4.0L engine. I use synthetic 10W30 in summer and 5W30 in winter.
My 2012 Xterra same engine, very solid built suv that will go anywhere, I’m looking to swap the M226 locking rear from the Pro4x model but honestly the forestry roads I take for trout fishing don’t require it
You can continuously cold start your vehicle with 5w40 at -30 below F. I'll just stand there and listen / watch
Any BITOG member here with a couple ounces of posts under their belt, already knows 5w40 is fine when the vehicle is warmed up, in a cold spell like 30 below. That's not why I differ.
Pleaase, no mentioning PAO oils that deliver great cold performances in 5w40. PAO is in very little oil brands & viscosities these days. But feel free to mention the 5w40 oil brands you cold start continuously without rattle at -30F. I'll folder them for future use / recommendations
Mine has the LS differential and I have to have it because my fishing and hunting areas often have thick mud (summer) or snow (winter).
S-model crew cab, short bed 4x4 with 16" steel wheels. I also have a set of 17" SV model alloys that I run on it.
I should elaborate in that handling, braking, visibility and the overall driver experience is great. The suspension is tough and will not bottom out. It's just that you get tossed and jostled harshly when on rough pavement.
Another oddity with the 2022+ is dash switchgear placement is all over the place. Not very ergonomic. Not a big deal for me as I'm not a big electronic options guy.
I know this sounds crazy but I’m seeing better MPG with the Purolator Boss filter. I’m seeing this in both my F150 & now the Frontier. The flow rates are very good with this filter and I believe this is contributing. Nissans computer tends to be very generous on its calculations but even at 27 - 28 MPG, pretty impressive. This was 100% highway, on-ramp to exit.
The Pro series has a Bilstein suspension. It can ride a little rough without weight, seems to improve a lot once you pack it up with gear and/or people.
The 2022+ are exactly like the 2nd gens in this regard. Turning radius isn't horrible until you get to the crew cab, long bed/wheel based models. With those, it's comically horrendous. Crew cab, long beds are very rare. Most are short beds.
Steering is a bit stiff on the 2022+ and they still use old school hydraulic rack/pinion which is nice.
My 2026 long bed crew cab is nice. Turning radius is what it is, not been an issue for me. It's not a sports car. Rides nice and quiet. Much better than my 78 Datsun King Cab and my 84 4x4 Nissan pk did. The Hankook tires need to be re-balanced and aren't the best riding tire, but it's not too bad. Certainly not worth buying tires until I wear these out. I like this truck.
  • Like
Reactions: JTK
Hey guys,
For your viewing pleasure. Some sparkles but not bad. Nothing notable in the can that I could see. Honestly, it’s what you can’t see that I am more concerned about. I went with the Puralator Boss filter. The inside of the media was clean. OEM filter seems OK, but not great. I wonder what the efficiency rating is.
This is why I do my first OCI very early, actually only 336 miles. I usually wait until 500 or so but I was bored today. Next one will be at 1500 miles, then every 5k after that. She also got a magnetic drain plug.
I'm following The Oil Geek's break procedure. Change at 500, 1500, 3500, 5000. No filter change until 5000. He's cut open the filters he has used so far. No need for a change.
