2024 F150 Tremor 5.0
Midland,MI
All,
I am new to ford vehicles. I picked up a new 2024 ford tremor f150 5.0 and was shocked to read not even recommending an early 1st oil change? 10,000 mile service intervals with oil change was not a shock to me.. I know the oil capacity is a bit more like 7 1/2 quarts or so. I didn’t see any UOA reports on these engines on this forum. Do any of you believe this 10,000 mile first run is a bit much?
All,
You'll get a lot of opinions on this, and truth be told; it may or may not matter.
My line of thinking is to do an early oil change between 1-3,000 and go from there. I also am not a huge fan or running out to 10K, but many folks do (and beyond) without issues. May depend on the engine as well, I recall some Toyotas that followed the 10K schedule and ended up being oil burners and sometimes motor issues later. I'm not sure on the 5.0, are they DI these days?
I would assume the 10k OCI is only applicable with whatever spec/certification requires. The number spec doesn’t come to mind easily.
I’m saddened that they are phasing out the glorious 5.0 across the line up; I think your trim is the highest you can get with the V8.
All,
Could be, but does Ford factory fill new vehicles with a high-moly oil? I ask because I believe Honda did that in the past. Honda wanted a full interval first run.
If you were looking to buy it certified used with 30,000 miles and it had never gotten that early oil change, but had regular maintenance done, would you still buy it? If so, then why worry about it now, but not worry about it after?
Either it matters or it doesn’t. That’s for you to decide.
The OLM is a bare minimum and more of a dummy reminder. My K20 had 20% left on the MM at 9800 miles.
I am not adressing the OLM. What I am saying is Honda, for an example, did not want an early factory fill oil change done. It was to allow the moly additive to do its work over a full interval.
If you aren't towing or race-tracking this PDFI engine, you could easily go 7.5k being the oil capacity is eight quarts.
I always roll 3k miles with the new factory fill, then I would do 7.5k OCIs afterwards.
I don’t trust people, especially dealerships who sell used cars. I try to buy new and take care of my way.
Thank you all for the replies. I did wonder if maybe from the factory they might have added something to the oil to help with the break in? Or a special oil on its own perhaps? I will not be doing 10,000 changes until at least a used oil analysis can prove me otherwise that this is safe.
only thing that scares me with long OCI’s in these is the wet oil pump drive belt.
The moly isn't in the oil, it's in the assembly lube. Changing the factory fill early with a quality synthetic is perfectly fine.
All,
IMHO its far too long.
I don't even go 10,000 miles now, on my 2014 F150 with 5.0.
