- Joined
- Jul 28, 2023
- Messages
- 339
That quote is from a dealer, not from toyota itself.Thanks for posting that. I've serviced, and have had serviced, a few of Toyota's hybrid transmissions over the past dozen years. These units need attention, just like any transmission.
From a Toyota bulletin that I got somewhere: Your 2023 Toyota Camry Hybrid transmission filter will need to be replaced every 30,000 or 50,000 miles. Be sure to check your vehicle's maintenance guide for more facts on mileage and time intervals.
https://assets.sia.toyota.com/publications/en/omms-s/T-MMS-23CamryHV/pdf/T-MMS-23CamryHV.pdf
Per toyota, (literally go to any toyota vehicle except the supra, gr corolla, and 86) none of their transmissions need servicing.
Do they need servicing? Maybe. When I serviced my 8 speed the fluid came out clean and red as if it was new after 50k miles. Is it over kill? Probably. Especially considering that the "cvt" in the hybrid is NOT a transmission, it is a coupler between the electric motor and the engine, that is it. Watch weber auto's tear downs of these. They are are simple as a coupler and torque converter system can get, which is why I probably wouldn't bother spending the time/money to change the little fluid that it has.
As far as doing it, it isn't as difficult. Just pour out the old, measure it, pour in the new. Trick will be getting a dealer to sell it to you. Most places that I see selling them are sketchy, and the cost is on the very high side for a fluid. 80$+?
Seen these hybrid "e-cvt" go for hundreds of thousands without service. Mostly because they are overbuilt.
