I might well be off a year here or there. Around 2017 the turbo was not to be found in a Sonata. Then the turbo reemerged as a 1.6T which had me scratching me head. When the 2.0T came back, the following year I believe, it was with the new colder NGK plug. Two & half-three colder heat range is quite the jump wouldn't you think?
Hyundai raised the white flag of surrender there. Perhaps not with Denso 20-22 move, but by the newfangled, "only" for the 2.0T, NGK the bums should have given a set to every 2.0T original owner as well as second owner factory certified.
One oil issue problem is shared. The pressurized turbo feed line, & to lesser extent the overflow\return turbo line, over time would leak. The plastic skidpad came with a foam type material that in essence was installed to absorb oil leaks. There's no other reason. So, for peeps that did not check the dipstick a rude awakening befell them. Especially anyone with OCI of 5K or better.
Mobil 1 0w40 os a good match. A light 40 grade that shears to a 30 by OC. You can hear the difference betwixt that and the syn blend 5-30 the dealer employs. I'm right at 100K and use 0.5qt by 3K. Dump a half in I'm good to 5K OCI.
I do not drive it "like I stole it" all the time. Howevah, I keep me foot in 'er arse on a daily basis. And I'm running around 22PSI burning 93 octane ethanol free. If she blows today, so be it. I've had the most fun out of this car than any other I've owned. The two turbo lines, the spongy spacer in the steering column, valve cover gasket, the orange dipstick, the brake light switch and at 97K+ the front disc pads have been changed. I bought the serpentine belt the other day, but I'm still pushing triple digits, on a regular basis, on the original. I've used synthetic in mostly in 5w-40 or 0w-40 for the most part with a couple of 5w30 changes around 40K along with one dealer semi-syn 5-30.
Maybe as the Sonata became wildly popular the QC dropped off as Hyundai was rolling 'em out the door as fast as they could. The direct competitor in 2011 was the Buick Regal 2.0T. Handled better, cost more and only claimed 250bhp. Which if I've not fallen victim to early onset dementia dropped quickly thereafter to around 230. Sound familiar?
Overall at this juncture I cannot in clear conscience bust the Sonata's balls. I never expected 300K much less 200K. I'm on me second fill of Frankenblend, different from the first, with the third jug, also different from the previous two, waiting to go. And, to add insult to injury I have two jugs of Valvoline primo bleu Restorie on the way.
Here's a bit o' advice from Simon Bar Sinister: Simon Sez, use a multigrade 40 and be the Italian tune-up; you've nothing to fear, but fear itself.
OK, a nod to FDR. I'm a plagiarist. Sue me.
Happy motoring kids.
Always warm the vehicle to operating temps before driving modestly for the first few miles. Then Va-Va Voom Pow!
