2018 F150-5.0V8 Kendall GT-1 5W30 9910 miles
USA
Code:
Unit mi.
3020 9050 17495 27190 37100
Oil mi:
3020 6030 8445 9695 9910
Fe 29 15 13 10 11
Cr 1 0 0 0 1
Ni 1 0 0 0 0
Al 4 3 3 3 5
Cu 29 7 2 1 2
Pb 1 0 0 0 0
Sn 0 0 0 1 0
Cd 0 0 0 0 0
Ag 0 0 0 0 0
V 0 0 0 0 0
Si 37 18 12 16 16
Na 10 3 3 2 3
K 14 4 0 1 0
Ti 0 94 97 100 100
Mo 70 21 17 16 17
Sb 0 0 0 0 0
Mn 17 6 4 3 4
Li 0 0 0 0 0
B 164 68 46 36 39
Mg 12 12 14 10 11
Ca 2051 2425 2397 2556 2489
Ba 1 0 0 0 0
P 687 739 720 734 715
Zn 751 834 789 854 822
Fuel%  Soot  Water
Vis100c 7.3 6.7 7.3 8.8 9.0
IOLM at 0%. Semi synthetic blend oil and a Motorcraft filter were used. Two things happened this cycle: the dealer reflashed the ECU to address several updates and the truck was parked through the coldest part of the winter. I don't know if either one is responsible for the decrease in fuel dilution. The first three numbers are from 5W20 and the last two are 5W30. The next UOA will be for the new Kendall SN plus which no longer uses Ti. The truck has occasional LSPI.
Code:
Unit mi.
Oil mi:
Fe 29 15 13 10 11
Cr 1 0 0 0 1
Ni 1 0 0 0 0
Al 4 3 3 3 5
Cu 29 7 2 1 2
Pb 1 0 0 0 0
Sn 0 0 0 1 0
Cd 0 0 0 0 0
Ag 0 0 0 0 0
V 0 0 0 0 0
Si 37 18 12 16 16
Na 10 3 3 2 3
K 14 4 0 1 0
Ti 0 94 97 100 100
Mo 70 21 17 16 17
Sb 0 0 0 0 0
Mn 17 6 4 3 4
Li 0 0 0 0 0
B 164 68 46 36 39
Mg 12 12 14 10 11
Ba 1 0 0 0 0
Fuel%  Soot  Water
Your 8 cylinder non turbo engine should not suffer from LSPI. That seems to affect small displacement 4 cylinder engines that have DI and are Turbo. Perhaps you have plain old engine knock or pinging, not as fatal as LSPI.
Whimsey
Whimsey
#1. This engine has 16 injectors, not the earlier 8. #2. Ford has a service bulletin re: the subject.
