2017 Corvette GS Declared Totaled over 1" Crack
Originally Posted By: Brybo86
JB WELD FOR THE WIN!!!!!!!
Duct tape
While I could not weld the Al sub frame , I am very confident someone could .
Then weld on bolt on a doubler plate .
Best wishes , :-)
In the industrial world critical things have to get repaired. You get engineering & welding experts together to write repair/welding procedures and even then decide if it's down rated 10% going forward etc ...
Heck, maybe the car would be limited to 120 in a 70 zone
You are correct...probably cost $10-$15k to get a qualified weld repair method down here in Oz...then implementing it.
Just gluing bits together with GTAW is not a "repair"...might work on teapots however...
Tig welding is not gluing.
Just a shot in the dark , has anyone asked if this is truely a crack ot a deep scratch / gouge ?
Best wishes , :-)
You could weld that no problem.
Unless it's magnesium. Plenty of mag parts in Vettes these days including sub frame parts, front and rear.
If the driveline tunnel is cast and solution heat treated aluminum, then welding it will put it in an annealed condition. The heat affected zone looses 2/3 of it's tensile strength in that instance. Now, it seems like a small area, but that driveline tunnel is probably seeing a large percentage of it's stress reverse when going over normal road variations. Cycle fatigue could result in the area cracking again, and in an undetected manner.
I'm not saying I wouldn't fix it and drive it myself. Im just pointing out that when using a material like heat treated, cast aluminum, field repairs to original specs become difficult to impossible.
