- Messages
- 20
Hi All,
Here is my first oil analysis ever with extended life.
7/25/20 (OLD) Setup:
Oil Used: AMSOIL Signature 0W-20
Filter Used: AMSOIL EA15K12-EA
7/25/20 (NEW) Setup:
Filter Used: Mobil 1 M1-108A Extended Performance Oil Filter
Commentary from AMSOIL Rep:
You made a good call by sampling after a long drive. That's a good way to get rid of raw fuel from start-up and this sample is indeed free of any measurable fuel. You'll find metals are in great shape compared to averages for the engine type. Iron is slightly elevated but that's what you can expect from normal accumulation since this oil run was longer than our 6,900-mile average. The viscosity is slightly high, so the oil thickened a little above grade but that didn't hurt anything. The 2.6 TBN shows active additive to spare since 1.0 or less is low. Try 15,000 miles.
MI/HR on Oil | 13,382 | |
MI/HR on Unit | 60,382 | UNIVERSAL AVERAGES |
Sample Date | 7/25/2020 | |
Make Up Oil Added | 5 qts | |
ALUMINUM | 4 | 4 |
CHROMIUM | 1 | 0 |
IRON | 17 | 10 |
COPPER | 1 | 3 |
LEAD | 0 | 0 |
TIN | 0 | 0 |
MOLYBDENUM | 187 | 160 |
NICKEL | 0 | 0 |
MANGANESE | 0 | 0 |
SILVER | 0 | 0 |
TITANIUM | 2 | 5 |
POTASSIUM | 2 | 3 |
BORON | 26 | 85 |
SILICON | 21 | 12 |
SODIUM | 10 | 22 |
CALCIUM | 1136 | 1551 |
MAGNESIUM | 1006 | 409 |
PHOSPHORUS | 694 | 663 |
ZINC | 803 | 753 |
BARIUM | 0 | 0 |
Values Should Be* | ||
SUS Viscosity @ 210°F | 58.3 | 46-57 |
cSt Viscosity @ 100°C | 9.73 | 6.0-9.7 |
Flashpoint in °F | 450 | >385 |
Fuel % | <0.5 | <2.0 |
Antifreeze % | 0 | 0 |
Water % | 0 | <0.1 |
Insolubles % | 0.2 | <0.6 |
TBN | 2.6 | >1.0 |
TAN | ||
ISO Code |
