2014 Odyssey Sludge/Varnish
Ok so I took the valve out today. I hadn’t bought a replacement yet, I have a dealer in MD that ships fast and sells at wholesale prices.
It was dirty, but it did rattle. It was hard to get out. It’s in a terrible spot, upfront but blocked. Here’s what it looked like when I pulled it:
And how it rattled:
I cleaned it with some carb cleaner and it dumped some dirt out, some of what looked like particles of sludge or varnish. The o-ring expanded when I cleaned the thing, thought it would be chemically resistant, guess not. I washed it with water and it seemed to shrink back somewhat.
I can’t say it rattles much different, but maybe?
The hole was slightly dirty too.
So I just don’t know. Not fully convinced that the PCV was clogged or bad. Maybe just contributing because of reduced flow?
nothing scientific but fyi, I changed the oil brand for couple of OCIs in one of our older cars (not going to mention the oil brand but it was a cheaper oil that met the spec) and i started to see residue and little sludge here and there (oil cap, etc.) even when I pulled out the dipstick, it sometimes had a little sludge on one edge of dipstick which I had never seen before ... so I went back to what I used to use which was M1 EP. I couldn't believe it maybe just a coincidence but I think it was the new oil. Car didn't like it or it had inferior or insufficient amounts of detergents ...
especially older cars still need more love and care with a better oil. I use a lot of M1 EP 10W-30 and recently been using some M1 Euro FS 0W-40 (jury is still out on this one) I'm sure there are other good oils but M1 EP is one superior oil.
Last two OCIs were Rotella Gas Truck. Before that has been valvoline, M1EP, and others.
I don’t run questionable oil, and this van doesn’t live a hard life other than short trips. But plenty of long drives interspersed.
Not convinced there’s anything wrong. Just being cautious - wasn’t expecting to see the golden varnish I did.
View attachment 80027View attachment 80028
And how it rattled:
It is not as bad as some I have seen, I did one with less miles than yours that would not come out, It broke and needed an easy out to twist it out. I see positive reviews on the engine cleaning product from High Performance Lubricants (I have not tried it yet but am going to on one particular engine in the spring), I would be tempted to give it a go in this engine.
And how it rattled:
We just bought a 2015 odyssey 2 months ago.
Same varnish and gunk as yours. 90k miles.
I have done 2 oil flushes with liquimoly proline engine flush.
I am doing a short OCI with lubegard and some 5w-20 oil.
2 tanks of SL-1.
So far after the 2 flushes the varnish has reduced noticeably and throttle response has improved.
I also muzzled the VCM during the first 2 weeks.
I think the piston rings were gummed up a lot.
Also, the PCV came out in 7 pieces.
New PCV improved engine performance also.
I think the VCM gums these v6's up.
Every week on the odyssey forums some new member comes on looking for help because they need new piston rings.
2 tanks of SL-1.
One most definitely needs to disable VCM on those v6's. Once we did that on our 2012 no more problems. It has been running 0w20 Pennzoil Platinum with FRAM ultra oil filter ever since we got the van.
Good call. Worth a shot as a mid-life service.
The 2005 and 2006 Odyssey models with VCM (Touring and EX-L) used the VCM 1 system which shut down the rear bank and went into "ECO" mode. these engines were fraught with issues usually resulting from extended oil change intervals over 3K or about 5K for highway/mixed use, the OLM and owners manual OCI was way too optimistic at circa 7500.
That OCI is almost a guarantee for sludge, heavy varnish, spool valve failure, the ones I have done have been fine even with VCM enabled on a 3K OCI. Even so they will commonly blow the $700 rear (actually the right) engine mount out at some point due to the 6-3 VCM configuration, disabling the VCM cures this issue as well as allowing a 5k OCI without issue.
The VCM 1 engines used a standard tension piston ring and did not have (or at least nowhere near as many) the ring issues associated with low tension rings found in the VCM II engines. VCM II uses a 6-4-3 with dual spool valves (one per bank vs rear only on VCM 1) this did help reduce vibration and blown mounts but the low tension rings exposed another issue that is the oil pumping into the cylinders of the ones shut down.
With both valves closed the pistons would allow more oil to pass into the combustion chamber than the standard tension rings, the end result was when the cylinders reactivated the excess oil would either fire if it was not too much oil and eventually blow the cats out and/or foul the spark plugs and misfire along with excess oil consumption. there were other issues with later models with the cylinder head also and PCV issues are common to both due to the valves extremely small diameter but this post is long winded enough so I will end it here.
Thanks Trav. I also own two 2006 Odysseys and two 2007 Odysseys. All are EX-L models with the VCM enabled.
Your advice is very accurate and very much appreciated. If there is any new or revised advice that you have on these engines, please reply to this post. Thanks.
@Trav: Thanks Trav for all your insight. You mentioned: "These engines were fraught with issues usually resulting from extended oil change intervals over 3K or about 5K for highway/mixed use".
I'm currently doing 4k mile / 6 month OCI with a 5W-30 full synthetic with lower Noack oil (ex I was thinking about extending to 5k mile / 6 month OCI, but just wanted your advice whether 5k is too long an OCI in these 2005 to 2007 Honda J35 VCM enabled engines. I was not fully understanding your statement above about whether 5k is too long an OCI on these engines.
Good discussion here. As another data point, our 06 Odyssey EX-L (with VCM Enabled always) has no oil sludging issues whatsoever with 188+K miles. Runs fantastic. Have done 36 oil changes to date. Average OCI is roughly 5200 miles (almost always do the oil change when OLM reads 30-40%). Reasonably clean front valve cover area when the valve adjustment was done couple years back. Probably going to keep up the OCI interval or even shorten it a little.
My father in law has had 3 of these an 05 with 300k and a 2012 with 200k+ and an 18 with about 70k.
He used nothing but Castrol GTX in the first 2 and they both were all varnish down the fill cap but ran like a top and didn’t really use much oil. Synthetic oil would probably keep it cleaner but doesn’t seem to affect longevity.
He does dealer oil changes now since he’s gotten older and we live to far away for me to do it for him.
I wouldn’t worry about it, carry on.
Just some info to add to this thread regarding the J35. Our 2023 Odyssey has had 3 oil changes so far (1k, 5k and now 10k mile marks, supertech 0W-20) I'd be curious as to what MPG others are seeing. We drove from NE Ohio to SC, over 640 miles doing 70 mph the entire trip and averaged 29.6 MPG. I'm more than impressed with this engine and vehicle in general. Very very good for over 4400 lbs curb weight.
We can do high 29s/just hit 30 on smooth steady highway trips.
It dips a lot to low 20s around town.
