Sedgehammer
- Joined
- Jan 17, 2023
- Messages
- 8
I think just regularWas this regular Mobil 1 or Mobil 1 EP?
SledgehammerHow do. This is the first analysis. The viscosity came up as 7.8 based the the cSt 100C test. The 10K OCI has a fair number of idling hours. More than would be normal. Since I'd like to stay with the 10k OCI, I should go to a heavier weight oil. Would 10W-40 be sufficient? Also, what is an acceptable viscosity when oil is changed? Thanks
I was going to post this as a PDF, but Bob doesn't like them apparently ........
looks good on paper, not so much in the real world.@jetman — you don’t think it’s a design (maybe even manufacture) issue more so then oil cleanliness???
There’s plenty of lifter failures posted online of new-ish engines. Those didn’t fail because of dirty oil and even 1,000 mile OCIs wouldn’t have prevented the failure.
You are En Fuego today.This seems to be the special edition (not sold anywhere but constantly mentioned) MOBILE phone version of Mobil 1 oil.
What I wanna know is what kinda sloppy lab technician puts 150,000 miles on the oil sample if the engine was noted to have 150k on it.
Looks like a perfectly Acceptable report for this type of vehicle. They are mostly all abused and destroyed beyond belief and come in with bone dry dipsticks, empty coolant reservoirs and crusty old & mangled K&N air filters dated 1990 (with a “good for 1 million miles - DO NOT CHANGE sticker on top) yet SOMEHOW still manage to function just fine from oil change to oil change.
These engines will then be pulled from the vehicle at the junk yard after 300,000 miles and installed into the next land yacht to abuse.
I suggest the OP continues on the chosen path that has worked for him for several vehicles in the past as stated. I’d love to keep watching this engine as it ages.
Willing to bet a 12qt case of Redline oil that the engine will be “just fine” and outlast the rest of the vehicle.
