That's Sulphated Ash alone.I believe the VW approval limit is 1.5%, it is the accompanying ACEA C3 that drives it to 0.8%.
There is no "sulfated ash" in the oil, that's only a measurement value derived from the ASTM test. But interesting, how is the SAPS value calculated beyond that test? How do you determine ash that isn't from a metallic additive? Both ACEA and VW describe the limit the same way.That's Sulphated Ash alone.
That's really only an issue when your dpf equipped diesel is both people and bug fogging from serious oil consumption and a tune if even applicable. But that's not really an issue with a stock no oil consuming engine being driven normally.you want a low ash oil, VW 507,
a CK oil may lead to DPF failure
the oils would protect the engine yes, but the ash may kill the very expensive emission control systems
How about VW 511.00/Porsche C40?
If I wanted to buy more oil I'd just buy more M1 ESP.How about VW 511.00/Porsche C40?
Eye of the beholder my friend! Lol2012 Touareg TDI
not 2023 Lamborghini Urus
Been running T6 5w-40 since day one in a Cayenne. No issues. Though my Wife has it rarely regen due to Sport mode and no emiss neuter.If a clogged DPF isn’t an issue, I’d run a HDEO like T6 for sure. This should be a good experiment.
This is true, but there is also a DPF clogging engine test in 507 00.I believe the VW approval limit is 1.5%, it is the accompanying ACEA C3 that drives it to 0.8%.
Your 3.0l (if you have one), is different to that of the Cayenne’s. Not in the least bit it does not have the emiss update. Porsche tuned it a bit differently and the Sport Mode is unique to the Cayenne as well. Between a 5000 change, 8-12oz is lost (probably evap of the T6). But driving is more aggressive and far more enjoyable.been driving a bit more spiritedly lately and have noticed the latest regen is 1000 miles ago. Of course, driving harder consumesa lot more fuel than the occasional regen, which uses about half a litre of fuel over 10 minutes.
They Cayenne has the same CNRB as the 13+ Touareg and Q7. Same hardware and software. Same for the transmission. I have the Cayenne gear logic enabled on my Touareg.Your 3.0l (if you have one), is different to that of the Cayenne’s. Not in the least bit it does not have the emiss update. Porsche tuned it a bit differently and the Sport Mode is unique to the Cayenne as well. Between a 5000 change, 8-12oz is lost (probably evap of the T6). But driving is more aggressive and far more enjoyable.
Your Turbo Diesel will do better with more load and rpm. The higher volume/rpm of air flow will also help keep the intake clean and lesson egr usage.
Hmmm, he is aware of that.Same software and hardware. Tune for Engine and Transmission are different as Porsche wanted it that way. Ask Oilhammer on TDIClub.
Regardless, my above statement on RPM and Sport mode lessons EGR usage.
Yeah, like I said, I have the Cayenne gear logic enabled.Hmmm, he is aware of that.
Dude, I don’t care where you stand on the differences between them. You drive your SUV and my Wife will drive hers.Yeah, like I said, I have the Cayenne gear logic enabled.
I'd have to see real proof of the Cayenne having a different engine map, not just "some guy said." They use the same hardware and make the same power.
