- Joined
- Jun 30, 2023
- Messages
- 300
There are several high performance tensioners on the market, but they are expensive. Worth it only if the owner plans to keep the vehicle for the long term. Essential if performance cams are installed. The K series (with turbo) is a common swap into anything imaginable. It’s the new LS swap.I'm not sure dealer would sell you an improved part in this case. They might simply be replacing it with a part that still has the same problem and it's a big job. Replacing the spring with the upgraded spring is the way to go as far as I'm concerned. It's much easier to do and has a greater probability of solving the problem. Why spend $1,500 on labor when you can do it with 1 hours worth of time and less than $100 worth of parts?
Also, is it possibility that the timing chain tensioner is causing the noise because they can also fail in a mode where they do not provide enough tension to the timing chain, especially at startup. There are YouTube videos on this also. It seems that this problem is more likely to be occurring the 2015 and Beyond models. But still it's possible that this is the problem for an earlier model. So if the variable valve actuator spring replacement doesn't solve the problem consider the timing chain tensioner upgrade as per the YouTube videos. It's best to fix this because both of these problems are putting extra strain on the timing chain which could result in it stretching to the point that it has to be replaced at a time interval much shorter than normal.
Replacing the timing chain tensioner is not really a big job because there is a small access cover to get to it. I think there may be some high performance Racing Equipment supply companies the people use whenever they use a K24 as the base for a build that Supply a upgraded design timing chain tensioner but I don't know their names.
Maybe somebody on this site can chime in with a name of a company that would Supply that?
The tensioner coming into play with the rattle is not from the tensioner itself - it’s absolutely the VTC actuator. Some other makes have engines where this is the case. When a Honda K series tensioner fails it will be too late before you figure that out. You are correct though, it is an easy job - BUT, you have to make absolutely certain that once the tension is off of the chain, you do not skip a tooth on the crank gear. Having the valve cover off, and jamming a prybar against the rear of the chain to keep tension after setting the engine to cylinder #1 TDC helps mitigate this from happening.
