If the steering wheel is shaking at idle when the car is in gear, does it smooth out when placed into park or neutral? If so, check the ATF level...those symptoms suggest low ATF and/or the torque converter is failing.2012 Honda Accord steering wheel shakes and feels like not shifting thru all gears. several times clunked when putting in reverse. Tires balanced and aligned ok.
Thanks
Sounds like a worn mount.
The clunk while shifting to reverse does indeed suggest a failed motor mount...typically the rear hydraulic filled motor mount.Have your had your motor mounts checked @monel777?
NoDid the wheel shop check for a bent rim or a tire that isn't round?
Driving2 different issues, more info needed. Steering wheel shakes sitting still at idle or while driving? You can count how many shifts you get and decide if you're not getting all the gears. Did everything start at once?
All at onceDriving
