I had my first ATF service done in August on the factory fill, here are the results. The Car is a 2012 Ford Fusion Sport AWD, this car uses an Aisin transmission in case anyone wants to know. They spec some funny kind of ATF from what I understand so I let the dealer do their thing. On a side note, if you ever get this kinda thing done at a shop be sure to specify if they're doing a drain and fill or a complete fluid swap. They simply did a drain and fill on mine, had i known that's what they were going to do I would have done it myself. This is my first transmission related report, let me know what you think.
Code:
Silicon was a little high in this sample, but that's probably from sealers and isn't likely anything to get too excited about. Metals are pretty good compared to averages, which are based on about 30,000 miles on the oil. Aluminum is a few ppm higher than average, but it's not so far out of line that we think it's anything to worry about at this point. It may drop with future samples, if some of this is wear-in. No coolant, moisture, or insolubles were found and the TAN was fine at 1.4. A fine sample, from what we see here. Try up to 50,000 miles (or so) next oil. OIL Amsoil Signature Series 5W20 MILES IN USE 32,150 MILES 32,150 SAMPLE TAKEN 08/06/13 ALUMINUM 20 CHROMIUM 1 IRON 69 COPPER 91 LEAD 1 TIN 2 MOLYBDENUM 0 NICKEL 3 MANGANESE 2 SILVER 0 TITANIUM 0 POTASSIUM 5 BORON 33 SILICON 43 SODIUM 7 CALCIUM 128 MAGNESIUM 1 PHOSPHORUS 271 ZINC 12 BARIUM 7 SUS VIS 210ºF 43.8 cSt @ 100ºC 5.34 FLASHPOINT ºF 390 FUEL% - INSOLUBLES 0.0 WATER 0.0 TBN - TAN 1.4
